haltech ?
with the e6k can you run an electromotive direct fire inigtion with a secondary row of injectors for a b20
Re: haltech ? (RCSIVTEC)
yes, it shows you how in the haltech manual
Re: haltech ? (Slow_ass_4dr)
Why would you want to run an electromotive ignition? It would require mounting their 60-2 trigger wheel.
The Haltech E6K will support sequential injection and direct fire itself with stock triggers. All you need is an older RX7 switching igniter and some dual post coils. |
Re: haltech ? (DirtyLude)
for the dual post coils can i just use to msd coils.
I have two used msd digital 6a's, dual post coil pack and modified b-series distributor so you can take your signal off the cams instead of the crank. Let me know if you are interested. All this stuff was used on a haltech set-up. 250.00 shipped.
You can't use the MSD unless they are dual post, meaning they have two ports for plug wires on each coil. Each coil fires two spark plugs at one time. You can get older RX7 dual post leading coils plus the trailing ignitor from a junkyard for dirt cheap. These coils will run more horsepower than most of use will ever see before needing a CDI.
[Modified by DirtyLude, 4:36 PM 5/13/2002] |
ok i see what you mean. i was looking throught the haltech website and was wondering with the direct fire am i going to need and msd box or not thats what i am not sure of. thanks dirty lude.
just buy mine....it's plug and play
| All times are GMT -8. The time now is 10:48 AM. |
