H2b TURBO guys HELP where to put oil return line
i have my whole setup complete but when i look at my oil return line to the oil pan i am scared that it will get clogged since the motor is tilted with the h2b kit.
any turbo h2b guys out there. please help trying to get the car running this week.
thanks for viewing
thanks for viewing
Re: H2b TURBO guys HELP where to put oil return line (fukenricen)
You can run a inline oil pump if the tilt is too much, that way the oil won't stay in the turbo screwing the seals up.
You could drop the return anouter 1/4" on the oil pan without any issues as long as you baffle the pan. Could probably got 1/2" at that point. Baffling it should eliminate any problems you'd run into while cornering.
