H22a turbo kit with type s cams?
can you guys help , I'm about to run a turbo set and I was woundering if I can run turbo with my type s cams already installed? as far as my set up on N/A here are my spec.
ported and polish head
.5 oversized black flat valves
type s cams
jg adj cam gears
ported intake manifold
springs and reatiners
stock jdm bottom block
can you guys help me out before I buy this kit, thanks alot in advance
Ray
type s cams
jg adj cam gears
Ray
Re: (raysjdmh22a)
Checked out the same thing with a number of sources. Dave @ D&H Racing said they work well and will produce more power than the regular version.
