h22, 8 psi, 2 heat ranges colder? gap?
im running h22, drop to 9.5:1 via headgasket, hondata s100, and msd digi-6+.
is 2 heat ranges colder ok? i got ngk coppers, bkr6e-11 (2756). also what gap is recommened?
Re: h22, 8 psi, 2 heat ranges colder? gap? (hondapwr)
well 2 heat ranges should be ok also, shouldnt it? i mean i already have them, and i like to get on it a lot, and its hot here in ga.
also since i have the msd, should i maybe open up the gap little more? or not?
Re: (meanteg)
i tried dendoaex, iridium, and ngk the last time i was at the dyno.i had to gap the ngk and denso all the way down to .025 and still had a miss here and there.the zex plugs worked without a hitch(they don't have to be gapped) and made 7 more whp than the ngk and 6 more whp than the denso
