---H E A D S T U D S--- ?????????
WHAT SIZE HEAD STUDS ARE YOU GUYS USING ON HI-BOOST(30+ LBS) B-SERIES ENGINES? I'VE HEARD STORIES OF GUYS USING STUDS LARGER THAN THE REGULAR ARP 11MM ONES. DRILLING OUT THE HEAD AND COILING THE BLOCK.
ANY INPUT WOULD BE GREATLY APPRECIATED
Re: ---H E A D S T U D S--- ????????? (mec. pedri)
the two optiosn is use the arp or go with 1/2inch studs but you have drill and tap as well as enlarge the opening
