guys show ur gt35r coolat lines on a kseries
Re: guys show ur gt35r coolat lines on a kseries (mini-cRx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mini-cRx »</TD></TR><TR><TD CLASS="quote">but than u would have to have the vent open mode to let colant flow anybody else </TD></TR></TABLE>
No. T it in before the valve.
Re: (1992Si)
looking at the engine bay on the right side of the valve cover there is a coolant line that makes a complete "u". cut the solid "u" fitting out, use two 3/8" barb --> 6 AN fittings, one for the feed and one for the return.
did this on one 35R setup and another 4094R k series setups and both r running flawlessly.
Re: (mini-cRx)
atp turbo has the fittings for the 35R
summitracing u can pick up the 3/8" barb to 6an fittings and the 6AN lines/hose ends
or you can talk to stan@fast-turbo and he can put together a complete kit for you. stan is a cool dude.
Re: (NJslvrtypes)
yeah i just talked to him actually iam getting kit from him but he wasnt sure where to hook them up thanks man check out my car if u want https://honda-tech.com/zerothread?id=2103514
