guess how much power this can be?
yeh i know its super rich
1000cc with 55base fuel psi
i know i made 460whp with 20psi and drag 3 intercooler
but now same setup little more boost and huge intercooler
just doing some street tuning tonight and clean up fuel map and trying to get the boost up ill get the air/fuel to 12-12.5 tomorow
Re: guess how much power this can be? (DLB1994)
My first reaction was...."nice 24psi". Then I looked closer and was like "Uhhh ohhhhh....94% duty cycle" May I ask why you have 94% duty cycle at only 460whp when using 1000cc injectors? You definitely need to up the pressure or something because 94% is <U>way</U> too high to be running injectors at.
Also, you sure do have ALOT of boost, high RPM's, and you definitely are barely even moving. I would have though with 24psi at 6000rpm's you'd be going a bit faster than 4.8mph hehe
EDIT: Boostfed beat me to it....not having the speed sensor hooked up would explain some things.
Re: guess how much power this can be? (Dunc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dunc »</TD></TR><TR><TD CLASS="quote">My first reaction was...."nice 24psi". Then I looked closer and was like "Uhhh ohhhhh....94% duty cycle" May I ask why you have 94% duty cycle at only 460whp when using 1000cc injectors? You definitely need to up the pressure or something because 94% is <U>way</U> too high to be running injectors at.
Also, you sure do have ALOT of boost, high RPM's, and you definitely are barely even moving. I would have though with 24psi at 6000rpm's you'd be going a bit faster than 4.8mph hehe </TD></TR></TABLE>
He was making 460whp BEFORE actually. We are sure he is making much more now with a bigger intercooler since his old one was getting heat soaked bad!
I figured I'd quote you Boostfed ....."When I made 616whp I was stock lines and filter, GE Fuel Rail, BIG Bosch pump same as Endyn sells."
Was this datalogging run at 24psi made on 1000cc's??
If so, isn't that implying that with a bigger intercooler and 4 more psi that he is likely to have gained <U>in the neighborhood</U> of 156whp or more? If so....damn!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dunc »</TD></TR><TR><TD CLASS="quote">I figured I'd quote you Boostfed ....."When I made 616whp I was stock lines and filter, GE Fuel Rail, BIG Bosch pump same as Endyn sells."
If so, isn't that implying that with a bigger intercooler and 4 more psi that he is likely to have gained <U>in the neighborhood</U> of 156whp or more? If so....damn!</TD></TR></TABLE>
Well when I made 616whp I was on 750cc injectors with really high base pressure. I had a 1.7 liter motor and Derron has a 2.4l or so motor.
PINKS
07-09-2006 10:46 PM
PINKS
07-09-2006 05:37 PM
pushinlsteg
10-02-2005 06:31 PM
GSRwBOOST
07-11-2001 10:33 AM
