Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Forced Induction (https://honda-tech.com/forums/forced-induction-16/)
-   -   GT30r issue (https://honda-tech.com/forums/forced-induction-16/gt30r-issue-2941477/)
ryguy2588 May 29, 2011 10:28 PM
GT30r issue
I have a GT3082r. I put some oil in the center cartridge and put it in the position where it would run and just spun the wheel by hand. I found that there was some oil on the compressor wheel and there were a few drops dropping out where the intercooler pipe connects to the compressor housing. There was no pressure, it was just some oil sitting in the cartridge. I assume bad oil seal, but I know a cartridge can't be rebuilt, but can a seal be replaced? There's not any shaft play. Or am I just out of luck?
ryguy2588 May 30, 2011 06:29 AM
Re: GT30r issue
Anyone?
TheShodan May 30, 2011 06:32 AM
Re: GT30r issue
If you're saying that you're finding slight amount of oil in the compressor housing and the car wasn't run, did you stand the turbo on its compressor side vertically? If so, nothing to worry about, as the sealing ring allows a little bit to go through. its when its under pressure, that's when the sealing ring expands and seals up.
If what your describing is oil in the compressor housing as the car has been running, that means you have a crankcase issue, and need a proper catch can.
But no, you can't replace a sealing ring on a GT-R series turbocharger.
ryguy2588 May 30, 2011 05:22 PM
Re: GT30r issue
3 Attachment(s)
Well its a used turbo and I haven't put it on yet. I was making sure that there wasn't any oil leaking before I put it on.
I put oil in the turbo, turned it like it was in use, and spun the shaft for about 5 minutes.
ryguy2588 May 30, 2011 05:23 PM
Re: GT30r issue
1 Attachment(s)
I looked in the compressor housing and saw a little oil coming out.
ryguy2588 May 30, 2011 05:25 PM
Re: GT30r issue
3 Attachment(s)
And then I took off the housing and saw the base of the wheel was damp and there was some oil in the housing.
ryguy2588 May 30, 2011 05:27 PM
Re: GT30r issue
The pics might be overkill, but I just want to make sure that either the seals are bad or it's just me being too worried about it before I use it or get rid of it. Thanks.
ryguy2588 May 30, 2011 05:28 PM
Re: GT30r issue
It wasn't standing up at all. I just kept it in the position in the first couple pics.
TheShodan May 30, 2011 07:45 PM
Re: GT30r issue
Doesn't seem like the worse thing in the world. It has to oil pressure PASSED the ring seal in order for it to be damaged. Keep it horizontal, try it on, make sure you're using the correct .030" restrictor on the oil feed, and give it a shot.
ryguy2588 May 31, 2011 08:08 AM
Re: GT30r issue
Ok. Thank you so much!
TheShodan May 31, 2011 08:29 AM
Re: GT30r issue
One other question. When you took the compressor cover off. was the turbo sitting horizontally when you removed that cover?
ryguy2588 May 31, 2011 08:40 AM
Re: GT30r issue
1 Attachment(s)
Yes I made sure to take it off while it was horizontal.
And this is the restrictor I have. It's tiny. Is it the right one? Should I just order another one?
ryguy2588 May 31, 2011 08:41 AM
Re: GT30r issue
I had to roll it from one side to the other to get to all of the bolts, but it stayed horizontal.
TheShodan May 31, 2011 09:07 AM
Re: GT30r issue
The restrictor you picked up, should be .030" opening. you can't tell much by the eyeball, but it looks to be right.
ryguy2588 May 31, 2011 09:15 AM
Re: GT30r issue
Ok. Thanks so much.
sh!ft Jun 9, 2011 02:17 PM
Re: GT30r issue
so let me get this straight, you are saying this turbo is acceptable to run like this? have you personally ever ran a turbo like this on a motor or in your car before? are 100% certain this will not effect the motor/turbo in any way, shape, or form??
TheShodan Jun 9, 2011 02:27 PM
Re: GT30r issue
(This is also in the PM I responded to)
I personally wouldn't have bought the turbo in the first place due to the mismatch of the wheel configuration that the GT3082R gave. Considering I don't know its full previous treatment, its not in my hands, I don't know if it was upside down for any length of time, There are a lot of variables to consider when seeing if thing really works, that can't be answered by pictures, no matter how good they are. I'll be honest, I'd have my doubts about this particular unit, (obviously so do you since you keep bringing this up,) but I have run some turbos like this before. It's not preferrable, but when it was needed I did, and it turned out ok. I don't know about this particular unit.
Sounds like you have some doubts, and for the price being asked, I don't blame you. Listen to your gut... Your spidey sense is tingling for a reason. If there is doubt, then don't buy it, and look for alternatives.
