gt28rs vs. gt2871r
gt28rs vs. gt2871r
which turbo would be better for a stock jdm itr for a all around good time?
what would make one turbo better than the other? im not a dynoqueen trying to get a supra power band, i want something fun and usable.
Re: gt28rs vs. gt2871r (type B16)
The only problem you'll have with the gt28rs - it will have such a wide powerband, that you'll feel bad only running 8-11psi. Quick-spooling turbos just seem to cry "high boost!". Otherwise it would be a great choice.
GT28RS > GT2871R... I've had both turbos running on my B18C, each turbo running at their respective power range.
I'd only go for the larger GT2871R if your mind is set to make above 320 WHP. Anything lower (esp for a stock motor), you can't go wrong with the super responsive GT28RS.
Re: (3S_EM1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 3S_EM1 »</TD></TR><TR><TD CLASS="quote">Why does it suck?</TD></TR></TABLE>
Typical noob response...
I am running the T2-based turbine housing with a T25 HKS manifold... I have no problem making power up to 8800RPM and the turbo has great response anywhere above 2500RPM... Although I do suggest the T3 drop-in housings for most turbocharged Hondas because all the popular turbo manifolds are T3 flanged anyways.
Re: (Tony the Tiger)
what do u recommend for A/R for the GT28RS and
A/R for the GT2871RS if i was to choose one for a stock <U>B18C</U> in an ek?
Also what is a decent power goal for a STOCK B18C Ek daily driver, (motor well maintained and running strong right now) ? me thinking 300ish whp, until atelast next year when i have more funds to build it.
Re: (armash)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by armash »</TD></TR><TR><TD CLASS="quote">what do u recommend for A/R for the GT28RS and
Also what is a decent power goal for a STOCK B18C Ek daily driver, (motor well maintained and running strong right now) ? me thinking 300ish whp, until atelast next year when i have more funds to build it. </TD></TR></TABLE>
i'm interested to knwo also
Location: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
Re: gt28rs vs. gt2871r (Tony the Tiger)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tony the Tiger »</TD></TR><TR><TD CLASS="quote">GT28RS > GT2871R... I've had both turbos running on my B18C, each turbo running at their respective power range.
But can it hold boost and make power to 8500rpm?
Re: gt28rs vs. gt2871r (boostincoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostincoupe »</TD></TR><TR><TD CLASS="quote">
But can it hold boost and make power to 8500rpm? </TD></TR></TABLE>
Well, you gotta look at the rest of your setup (cams, intake manifold, exhaust manifold, exhaust system/downpipe, cam timing, etc).
My particular setup made power until 8000RPM, then it stayed flat and starts to slope down after 9000RPM. Setting my shift points at 9200RPM resulted in the fattest powerband possible. My oddball setup doesn't relate to anyone here though, so I simply do not have a straight answer for you.
