GT Series Turbo Question
Old 12-08-2003, 07:48 PM
djdxm's Avatar
Default GT Series Turbo Question
I know the main reason about price being why more ppl dont choose the GT Series turbos. But im curious for high HP applications What turbo would you use? I see alot of ppl using the PT67 and the PT70 turbos and keeping them spooling pretty easily with p trim turbine sides. What about something like a GT40R. Also what trim options would be good. Anybody use this or have experiance with it? Would it perform well like a PT70 would?
Thanks
Jay
Old 12-09-2003, 08:25 AM
djdxm's Avatar
Default Re: GT Series Turbo Question (djdxm)
*jay listens to the crickets*
i guess that answers my question
Old 12-09-2003, 10:13 AM
liam821's Avatar
Good question. I would like to know also.
Just looking around on the internet i found...looks like the GT40R would be a nice match up for the PT67 ptrim.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Nelson did run a a career best ET of 8.146 seconds at 192.38 mph in his 2003 Bothwell Motorsports ’03 Chevy Cavalier, and in the same run became the first Pro FWD car to run in the 190 mph range. Click here to read more. Bothwell motorsports has equipped the Chevy Cavalier with a Garrett GT45R</TD></TR></TABLE>
But the GT45R is just too big i think....unless your going totally full-race with NOS.
Also some guy with a jetta said:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Brian had previously ran an older T72 turbo with this setup. He found that even though the T72 flows more air, the GT40R made a much broader (more usable) power band that consistently made it easier to launch and net a better 60 ft. time and 1/4 mile ET.</TD></TR></TABLE>
liam
Old 12-09-2003, 10:20 AM
Buraku's Avatar
Garret doesnt sponser this board so everyone is gonna suck precision dick.
Old 12-09-2003, 10:49 AM
Smarter than you
DIRep972's Avatar
Default Re: GT Series Turbo Question (Buraku)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Buraku &raquo;</TD></TR><TR><TD CLASS="quote">Garret doesnt sponser this board so everyone is gonna suck precision dick.</TD></TR></TABLE>
Just FYI, Precision uses garrett CHRA's...
Old 12-09-2003, 11:08 AM
AROD's Avatar
how is the GT-35R is it good for the street? and racing?
Old 12-09-2003, 11:10 AM
AROD's Avatar
Default Re: GT Series Turbo Question (liam821)
whats does P trim mean in # wise.
Old 12-09-2003, 01:36 PM
liam821's Avatar
Default Re: GT Series Turbo Question (1.83Tc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1.83Tc &raquo;</TD></TR><TR><TD CLASS="quote">whats does P trim mean in # wise.</TD></TR></TABLE>
Its just a type of exhaust wheel. They come in a few different sizes.
liam
Old 12-09-2003, 02:31 PM
Buraku's Avatar
Default Re: GT Series Turbo Question (DIRep972)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DIRep972 &raquo;</TD></TR><TR><TD CLASS="quote">
Just FYI, Precision uses garrett CHRA's... </TD></TR></TABLE>
Some of them use garret wheels too. Its like a non-ballbearing garret with crappy housings (I dont like the way they look anyways).
Old 12-09-2003, 05:00 PM
liam821's Avatar
Some of them use garret wheels too. Its like a non-ballbearing garret with crappy housings (I dont like the way they look anyways).</TD></TR></TABLE>
crappy housings? Are you crazy? Precision has some of the best housings made! Show me a turbo that will make almost 400whp at 10psi ,and hit full boost at under 5000rpms, and cost under $800 and ill show you a sc61.
liam
Old 12-09-2003, 05:07 PM
Buraku's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by liam821 &raquo;</TD></TR><TR><TD CLASS="quote">
liam</TD></TR></TABLE>
I simply stated I dont like the way they look, thats me. 10psi at what rpm? 10psi isnt alot of flow, theres alot of turbos that can flow enuf air for 10psi and spool up alot quicker than 5000rpm. You will have a hard time convincing me that a sc61 is significantly more efficient than a smaller turbo at 10psi.
Old 12-09-2003, 05:12 PM
Mr. Softee's Avatar
the GT turbos rule. Id definitely get a GT40 over a PT series turbo
Old 12-09-2003, 05:39 PM
Smarter than you
DIRep972's Avatar
I simply stated I dont like the way they look, thats me. 10psi at what rpm? 10psi isnt alot of flow, theres alot of turbos that can flow enuf air for 10psi and spool up alot quicker than 5000rpm. You will have a hard time convincing me that a sc61 is significantly more efficient than a smaller turbo at 10psi.</TD></TR></TABLE>
Sure alot of turbos can flow enough air for 10psi, but there is a big difference between pressure and VOLUME.. There is not another turbo on the market that can spool faster then an SC61 and push the same volume of air except the Garret GT35R(retail: 1800$)... and guess what?? Thats where the SC61 gets its compressor wheel from!!!!!!! So unless you have some kinda factual data please leave your opinions out of this discussion. Thanks
Old 12-09-2003, 05:56 PM
Mr. Softee's Avatar
I dont know if I agree with that direp, the exhuast wheel on the GT35R is GT series, vs. a standard t3 or t4 style for the SC61. The GT35R should flow a little more because of this. I also would chose the GT35R for obvious reasons, ie being a BB turbo... but the sc61 is a great value.
Old 12-09-2003, 06:26 PM
Smarter than you
DIRep972's Avatar
Default Re: GT Series Turbo Question (94goldjungsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94goldjungsr &raquo;</TD></TR><TR><TD CLASS="quote">I dont know if I agree with that direp, the exhuast wheel on the GT35R is GT series, vs. a standard t3 or t4 style for the SC61. The GT35R should flow a little more because of this. I also would chose the GT35R for obvious reasons, ie being a BB turbo... but the sc61 is a great value.</TD></TR></TABLE>
yes, the GT35R uses the 82 trim GT exhaust wheel. It makes about 15 more hp then a standard stage 5 T350 wheel and spools up the same. (non-ball bearing of course) If you can afford the GT35R I am all for it, I absolutely love that turbo..
Precision now offers a new version of the SC61 that is the same as before but u get the 82 trim GT exhaust wheel on it instead of the standard stage 5 T350. It costs a lil more then a standard SC61 but to some people it will be worth it. Im not sure on the exact price contact Arturbo if anyone is interested. I think he just got like 8 or 9 in stock. One of which is MINE!
Old 12-09-2003, 06:42 PM
Mr. Softee's Avatar
Precision now offers a new version of the SC61 that is the same as before but u get the 82 trim GT exhaust wheel on it instead of the standard stage 5 T350. It costs a lil more then a standard SC61 but to some people it will be worth it. Im not sure on the exact price contact Arturbo if anyone is interested. I think he just got like 8 or 9 in stock. One of which is MINE! </TD></TR></TABLE>
I believe they are about ~$950. Wonderful turbo for the price If ball bearing is not a concern, is perfect!
Old 12-09-2003, 07:55 PM
E-thug
boostismycrack's Avatar
yeah, I just got one of these turbos from precision. It looks bad ***, I'll put it on next week.
Old 12-09-2003, 08:01 PM
SiRkid's Avatar
Default Re: GT Series Turbo Question (boostismycrack)
i rike my gt.
not quite as powerful as an sc61 or gt35r but its not far behind either.
Old 12-09-2003, 09:41 PM
TrueNorthStar's Avatar
I believe they are about ~$950. Wonderful turbo for the price If ball bearing is not a concern, is perfect!</TD></TR></TABLE>
Art does have them, I think he said about $950....... now did you know you could that you can get it with the ball bearing .
Ask Arturbo he is the one that told me about them.
Modified by TrueNorthStar at 7:14 AM 12/11/2003
Old 12-10-2003, 12:19 AM
Mr. Softee's Avatar
Default Re: GT Series Turbo Question (TrueNorthStar)
if you are going to get it w/ the BB you might as well get the GT35r, I believe the GT housings are more advanced than the standard ported t04e/s/t3 housings that precision offers.
Old 12-10-2003, 12:36 AM
I'm not sure, but I belive it comes with a differnt turbine housing than the SC series.
When I ordered my SC61 from Art, he sent me one that had the integral wg port. So I sent it back and he said he didn't have any SC turbine housings with out the hole at the time. So he said he would hook me up with one of the new precision's cause he had thoes without the wg port. ( to Art)
That is when I learned about the BB version ...
Modified by TrueNorthStar at 10:00 AM 12/10/2003
Old 12-10-2003, 10:42 AM
Smarter than you
DIRep972's Avatar
A Garret GT35R vs. a Precision ball bearing SC61 w/ GT35 exhaust wheel would be a tuff choice.. The GT35R comes w/ a 4-bolt exhaust housing while the Precision comes standard w/ a 5-bolt. The GT35R comes standard w/ a .70ar "S" housing while the Precision comes w/ a .60ar "E" housing, but the "S" is an option to upgrade. What we have found though w/ the SC61 is that it really likes the "E" housing and we never really reccomend the upgrade. I guess in the end you would have to make ur decision on fitment w/ ur set up, customer service, and price.
Old 12-10-2003, 11:08 AM
*Boostwerks*'s Avatar
"I simply stated I dont like the way they look, thats me. 10psi at what rpm? 10psi isnt alot of flow, theres alot of turbos that can flow enuf air for 10psi and spool up alot quicker than 5000rpm. You will have a hard time convincing me that a sc61 is significantly more efficient than a smaller turbo at 10psi."
Sure alot of turbos can flow enough air for 10psi, but there is a big difference between pressure and VOLUME.. There is not another turbo on the market that can spool faster then an SC61 and push the same volume of air except the Garret GT35R(retail: 1800$)... and guess what?? Thats where the SC61 gets its compressor wheel from!!!!!!! So unless you have some kinda factual data please leave your opinions out of this discussion. Thanks</TD></TR></TABLE>
Hahahahaha...this Newb (Buraku) obviously has no idea what he's talking about.
OWNED.
Old 12-10-2003, 03:48 PM
SiRkid's Avatar
the bb that will be offered with the precision turbos will be exactly the same as garrett's?????????????
if so, there no way it wont drive the price up much higher.
the garret housings are also more advanced.
everything is "cleaner" too. the housings casts etc.
Old 12-10-2003, 04:16 PM
RedlinedVTEC's Avatar
Default Re: GT Series Turbo Question (Bryson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote"> Hahahahaha...this Newb (Buraku) obviously has no idea what he's talking about. </TD></TR></TABLE>
Hmm Bryson I think you're the one that looks like an *******... Buraku aka Blake created Uberdata so he obviously has no clue what he's talking about.
Quick Reply: GT Series Turbo Question
