GSRs w/Fluidyne radiator and Revhard or Drag Kits.. A/C Fan???
New User
1) Anyone find a real solution for mounting an A/C fan?
2) Anyone know of a metal fan of 2" depth?
3) How close can a plastic fan be to the turbo without melting?
4) If you mounted the fan in front of the condensor, how did you reroute the
oil cooling lines?
5) What size fan fits in front of the condensor?
6) Can I just mount a fan on the Intercooler as a puller, which would blow air at the condensor? (Enough heat dissapation for the condensor???)
oil cooling lines?
New User
Re: GSRs w/Fluidyne radiator and Revhard or Drag Kits.. A/C Fan??? (CovertFI)
Is that a SPAL fan, and what size?
Also, how did you relocate the oil cooler?
New User
Re: GSRs w/Fluidyne radiator and Revhard or Drag Kits.. A/C Fan??? (echo999)
Also, your lights look like a Civic.. do civics have an oil cooler in front of the
condensor?
condensor?
2nd i bought it from summit under the summit name
3rd oil cooler?
4th the only problem was the ac line and i just bent it with my hand.
5th i think it was a 10 inch fan. it was the smallest they made and it just fit.
New User
So anyone who has a GSR help me with this?
I guess maybe not that many people run Fluidyne radiators in GSRs
I'm interested too... the oil cooler is that loop thing in front of the radiator right?
