Gsr Turbo Questions??????
I have 98 Gsr integra with 60,000 miles on it. Im thinking about going turbo and want to know which is the safest setup for reliability and speed on a stock motor? Gie me some options on what i need to do or fix and check before doing so.
Re: Gsr Turbo Questions?????? (dson78)
check compression and do a leak down test if you want to, just to be on the safe side. If your planning to run on the stock ecu, then just get yourself one of those bolt on turbo kits, running 7psi will be fine.
Happy boosting!
Happy boosting!
Re: Gsr Turbo Questions?????? (ekb18c)
Is 7psi the highest and safest a gsr ekb18c motor can run to be a daily driver? About what horse power does 7psi produce out of a stock engine? Do i need to change the clucth or sleeve the motor at 7psi?
akcapr
10-04-2010 04:03 PM
