Gsr-turbo head bolt torq?
Im building back my gsr-t and i don't know the torq? spec of the head bolts. The bolts are stock bolts do you still torq them to factory spec or a little tighter because of the turbo.For you guys that know for sure please tell me the torq specs thank you
Re: Gsr-turbo head bolt torq? (marcussmith26)
if they are used
you will probably blow your headgasket within the first boost
you torque them to stock spec with new headbolts
but i would recommend arp head studs
Re: Gsr-turbo head bolt torq? (komat)
you really shouldnt be using factory headstuds....like they said get a set of arps
if oyu want to try it out go to 61-63 ft lbs
junglerunna
01-20-2005 09:31 AM
