GSR Main Girdle on a B18B (LS)
Old 06-16-2009, 10:44 AM
extremeracer's Avatar
Default GSR Main Girdle on a B18B (LS)
Hi
Im wanting to fit a GSR main girdle on my LS/Vtec (B18B block) build.
I know that you need to use the GSR oil pickup and windage tray and sump with the conversion.
What I need to know is - can the 3 cap girdle work on the LS main caps (using the GSR pickup windage tray and sump) - or must you use the GSR main caps in order to fit the girdle ???
Im trying to avoid replacing the caps on the motor and needing to line bore it afterwards.
Thanx in advance for the help !!!
Old 06-16-2009, 09:57 PM
Default Re: GSR Main Girdle on a B18B (LS)
Bump for info - plz
Old 06-17-2009, 03:19 AM
non-VTEC's Avatar
just buy a golden eagle or endyn girdle. it bolts up with no machining required.
Old 06-17-2009, 10:07 AM
omgwtfbbq's Avatar
http://shopping.lightningmotorsports...cat=155&page=1
here ya go....lots of good ls/vtec conversion stuff on that site.
Old 06-17-2009, 11:13 AM
AK94GSR's Avatar
i would just get the golden eagle girdle. if u use the gsr girdle with mains a line bore is a must since your tryin to put 2 diff motors together
Old 06-17-2009, 10:12 PM
Ive found a Z10 3 main cap girdle - and I have GSR main bolts - so all I'd need then would be the GSR oil pickup and oil pan or Moroso oil pan
Is this right ???
Old 06-18-2009, 03:57 AM
non-VTEC's Avatar
you need the B18C main bolts, windage tray, oil pickup, oil pan.
Old 06-18-2009, 07:23 AM
CerealKiller's Avatar
...and you are changing the torque sequence.
Old 06-18-2009, 07:28 AM
Golden Eagle's Avatar
Is this right ???
the z10 girdle is ok but be sure you dowel it to the mains. if it does not have dowels connecting it to your main caps you might as well not even put it on as it will do nothing for you. the b18c main girdle is doweled to the mains for a reason.
Old 08-02-2010, 07:50 AM
low13da9's Avatar
ttt
ganjasnack
01-24-2007 08:30 PM
j87w
03-29-2005 09:24 AM
SM 30 Hatch
10-07-2004 04:12 AM
srt4thatazz
07-11-2004 06:05 PM
vbphreak
11-25-2002 09:51 AM
Quick Reply: GSR Main Girdle on a B18B (LS)
