GReddy TD04H 15g water cooled??
sup guys, i have a 92-95 greddy turbo kit on my 99 civic sohc and was wondering does anyone else out there know anything about this kit being water cooled? b/c i see 2 LONG copper nipples coming out from the turbo and was told that its for water lines. this turbo, itself has a Mitsubishi DSM B.O.V. built on will i be ok if i didn't hook a vacuum line to it to actuate the bov? b/c im currently running a aftermarket bov on my charge pipe n didn't connect the original one.
Re: GReddy TD04H 15g water cooled?? (ek9 ferio)
the bov may leak boost once the turbo creates pressure. without a boost signal to keep it closed it might open. it woudl be ideal to weld the bov shut or do something to prevent it from opening.
The 2 copper lines from your turbo are likley water lines. tap into your Throttle body and you shoudl be good to go.
Re: GReddy TD04H 15g water cooled?? (digitalhav0c)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by digitalhav0c »</TD></TR><TR><TD CLASS="quote">blow off valve on the turbo? maybe im just confused does he maybe mean the wastegate? </TD></TR></TABLE>
no for the 1000th time its not the internal wastegate, the wastegate is above the bov. and as for tapping the water line, i can't b/c the kit came off of a 92-95 civic and the kit is on my 99 sohc motor and the copper nipples has no clearance to hook up due to it hitting the clutch slave.
Re: GReddy TD04H 15g water cooled?? (CRXdan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXdan »</TD></TR><TR><TD CLASS="quote">the bov may leak boost once the turbo creates pressure. without a boost signal to keep it closed it might open. it woudl be ideal to weld the bov shut or do something to prevent it from opening.
The 2 copper lines from your turbo are likley water lines. tap into your Throttle body and you shoudl be good to go.</TD></TR></TABLE>
CRXdan, do u think i can get the bov to be welded shut w/ the turbo still on the car? i was thinkin about it leaking boost as well but i wasn't sure b/c i know in order to actuate the bov its gotta be hooked up. thanks in advance
lillthingz
02-13-2005 03:54 PM
