Greddy profect B boost controller install I searched
how to install this boost controller
i checked the greddy site and they updated their site and i dont see the tech help there. anyone know how to install and how to set the settings for 8psi ? |
cant be done. sell it to me. https://honda-tech.com/forums/images/smilies/emwink.gif
Re: (Turbo E 604)
bump
Re: Greddy profect B boost controller install I searched (GReddy SI)
If memory serves corrrect, set your gain for .55 and set your initial duty gain at 10-15%. If you drop boost, up your duty gain. If you spike, lower it. Set your warning for about .56-.6. You may have to play with the gain and duty gain settings until you get a nice constant boost. You can always lower the gain and increase the duty % gain to increase the amount of boost being created.
I also noticed they changed their site around. Lucky you. |
Re: Greddy profect B boost controller install I searched (PrecisionH23a)
.55 is for 9psi?
anyone know how to install it ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GReddy SI »</TD></TR><TR><TD CLASS="quote">anyone know how to install it ?
</TD></TR></TABLE> i would like to know too... |
Re: Greddy profect B boost controller install I searched (SPOON_BeIgHtEeNsEe)
I got the manual at my house man, be out there in a bit and i can scan the pages for you.
Re: Greddy profect B boost controller install I searched (phreakmang)
anyone?
Ok here ya go...
Run the wires through to your engine bay, the one that comes off of the filter goes to a Y that splits off on your fuel rail (FPR / Intake Manifold). The other 2 hoses that come off the black box. The left side goes to a vac source, the right port goes to the side of your wastegate. Then the top port of your wastegate to a vac source. Power and ground it and your done mang. http://www.we-todd-did-racing.com/we...MXk1NDE%3D.jpg hah! |
I think I have the instructions at home in PDF.
and I'll send it to you. |
u got email
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phreakmang »</TD></TR><TR><TD CLASS="quote">Ok here ya go...
Run the wires through to your engine bay, the one that comes off of the filter goes to a Y that splits off on your fuel rail (FPR / Intake Manifold). The other 2 hoses that come off the black box. The left side goes to a vac source, the right port goes to the side of your wastegate. Then the top port of your wastegate to a vac source. Power and ground it and your done mang. http://www.we-todd-did-racing.com/we...MXk1NDE%3D.jpg hah!</TD></TR></TABLE> so none of the tubes goes to the turbo housing? i have mine installed while back took the hoses off now i have different setup and i forgot how to put it all the tubes back lol.. |
could sumone send me tha wiring diagram also my email is kraisant@aol.com
i have mine hooked up but i dont think its right i have top of wg to the black box, and side of wastegate to y tee and it goes to intake mani vac source and other goes ta box |
Re: (aznballer)
line up to give me blow jobs
(internal wastegate) http://scuderiaciriani.com/rx7/profec1.jpg (external wastegate) http://scuderiaciriani.com/rx7/profec3.jpg http://scuderiaciriani.com/rx7/profec2.jpg http://scuderiaciriani.com/rx7/profec4.jpg |
Re: (Toda Party)
hm....the actual booklet shows to hook up
side port or wg to vac, top port to what is labeled (3) in the diagram. then (2) going to the vac also. how would you hook it up to the charge pipe, and what would that do besides give vac? |
Re: (phreakmang)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phreakmang »</TD></TR><TR><TD CLASS="quote">hm....the actual booklet shows to hook up
side port or wg to vac, top port to what is labeled (3) in the diagram. then (2) going to the vac also. how would you hook it up to the charge pipe, and what would that do besides give vac?</TD></TR></TABLE> see i knew it one goes on the fitting on the turbo https://honda-tech.com/forums/images...es/emsmile.gif |
Re: (egturbo)
that picture is not showing it going to one of the ports on the turbo
Re: (phreakmang)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phreakmang »</TD></TR><TR><TD CLASS="quote">that picture is not showing it going to one of the ports on the turbo</TD></TR></TABLE>
The part labeled "charge pipe' is going to be the same as the port on the turbo. Follow the pic it works. |
Re: (Doodoo)
roger mang, thanks.
Re: (egturbo)
so where does in and out go?
Re: (egturbo)
(2) right side goes to the nipple on your turbo
(3) left side goes to the top of your wastegate Then go off the side of your wastegate to your vaccum source, as the picture shows. |
Re: (phreakmang)
it'll be easier if u explain in or out. cuz people mount their profec boxes different mines hidden somewhere and dont know which one is left or right lol. if u can explain in and out i would know thanks man.
for some reason one of my tubes that goes to the wastegate or turbo is t'd off to vacuum |
what should the settings be for 10psi boost on tha profec b spec 2 anyone kno i have it set at gain 10% duty rate50% and warning at 20%
