GReddy kit owners...anyone retarded the timing?
I just wanted to know if any of you guys retarded the timing while still using the GReddy FCU (Blue box)? If so, what's your timing at now? Mines at 14 degrees since I'm using 91 octane gas.
Thanks in advance...
Re: GReddy kit owners...anyone retarded the timing? (FBP Si 2000)
how much boost are you pushing? mine is not retarded at all, even when i was boosting 7. i'm brought the boost back to 5 until i get my DSM injectors put in.
Re: GReddy kit owners...anyone retarded the timing? (thermalfi'd16)
Well, call me retarded, but I'm running stock timing (was at 9psi for a few days, though it was sketchy) and now at 7psi, and no problems that I can tell. I am, however, installing a 6btm, tomorrow, so it won't really be an issue
I thought that the FCU retarted you timing for you? guess not huh? i would retard 1 degree even at 7psi.
5psi?how do you do it.. that maybe lastest 2 days for me,, we are now at 12PSI on a stock B18b1 and I wanna go higher!!!
boost is addictive!
boost is addictive!
Re: GReddy kit owners...anyone retarded the timing? (ATgrills.com)
boost is addictive!
boost is addictive!
I have been running the Greddy Turbo kit with the Hondata, and i was told to keep the timinig to stock (16 degrees) atleast up to 10psi.
-deepsi
-deepsi
Re: GReddy kit owners...anyone retarded the timing? (DeepSi)
Perhaps someone with some insight how the MSD boost timing units (or J&S safeguard) units retard timing can answer this question?
I wasn't aware you could run stock timing on 91 octane. Is anyone doing this and monitoring their knock sensor / EGT?
Thanks
Thanks
5psi w/ Blue Box and Stoc Timing, but then again I use 93 octane gas
Id say give GReddy a call just to see. Maybe Ill call them tomorrow @ work.
