greddy blue box w/apexi controllers help!!!
ok here's the problem...i got that shitty piggy back blue box on my girls turbo set-up and i wanna run more boost...
i hooked up a apexi vafc and avcr boost controller... was wondering if anyone has done this and if it will work accordingly since the blue box is preprogrammed...i don;lt know if it will allow me to boost more or note...etc etc im thinking of just going fmu with 10/1 ratio any help from turbo heads will be appreciated thanks... boost https://honda-tech.com/forums/images...s/emthdown.gif n/a https://honda-tech.com/forums/images/smilies/emthup.gif |
Re: greddy blue box w/apexi controllers help!!! (accorse07)
c'mon someone help
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accorse07 »</TD></TR><TR><TD CLASS="quote">
boost https://honda-tech.com/forums/images...s/emthdown.gif n/a https://honda-tech.com/forums/images/smilies/emthup.gif </TD></TR></TABLE> Shut the fuck up. Go have fun with your slow friends over here: https://honda-tech.com/zeroforum?id=44 |
i have done it how much boost are you looking to run
and what is the set up https://honda-tech.com/forums/images/smilies/emthup.gif |
Re: greddy blue box w/apexi controllers help!!! (1.8turbolsvtec)
stock single slam...d16y8...i got a fmic, 310 injectors, gsr fuel pump, and a vafc hooked up for fuel ajustments...the blue box is also hooked up along with the apexi boost controller so im plannin to run about 10-11 pounds...just wondering if the blue box will need to go or it can stay and work togther with the apexi controllers.
i had a friend that went 9 to 10 psi on a stock d16y7 with 310 and the blue box and a 255 pump for the last 2 years https://honda-tech.com/forums/images/smilies/emthup.gif
ok that's good to know but i wanna know if the apexi controllers will work in conjunction with the blue box...
yes it will work
it should work
