Greddy BLUE BOX & OBD1?? i searched, no help...
hey guys, i spend the past like 2 weeks searching and reading all the threads that had blue box discussions....but none really answered my questions...so here it is, plain and simple, because i've read threads on HT, and all over the internet with different answers...
DOES THE BLUE BOX WORK WITH OBD1?
it was made for obd2, ok i know that...and yes i know greddy kit isn't an uber cool 30psi 800whp kit...so lets not get into all that...i just want to know...
WILL THE BLUE BOX RUN MY OBD1 GSR CORRECTLY WITH THE GREDDY KIT?
im currently running vortech fmu, and missing link...but i'd like to run it with the bluebox...
i already have the wiring all matched up and cross-referenced from obd2 to obd1 and everything. so i know i can wire it up, but will it run correctly?
again, im not looking to make max hp or do anything special, i just want a reliable, boosted gsr, street legal in CA...so please help me!
(also...if i run the blue box, do i still need the missing link?)
thanks guys!
thanks guys!
Mr. Badwrench
Re: Greddy BLUE BOX & OBD1?? i searched, no help...
http://greddy.com/img/PHP/products/pdf/828.pdf
looking at greddys site it just shows, 4 injectors, and the map intercept. i know it will work on an obd1 car, and i never noticed a difference between the boxes per obd.
also...heres a cheat-sheet i made myself based on the greddy install guide for bluebox, obd1, and obd2 pinouts...let me know if this looks right guys...
here is what i ended up with...so in the "obd1" column, is what im going to be tapping into...
here is the greddy pinout for obd2
here is obd1 wire diagram/pinout
and this is obd2 wire diagram/pinout
Mr. Badwrench
well since the p06,28,30,and 72 all share the same wiring, the bluebox wiring for the d series, p28 will be the same for all 4.
ok...still doesn't help me, and as you can see...I already know how to wire it up. I know the pinouts and have figured out how to convert from obd2 to obd1 wiring...
read my thread/post please
im asking if it'll run correctly on obd1 gsr.
bump...any1? im about to wire it up tonight, so i just want a last minute yes or no, haha
official honda whore
i wouldnt see why not
still not as good as the obd1 programs that are out there to adjust the timing as well as other things
are u running the ORIGINAL greddy blue box or the blue emanage? the e manage (rectangular, not square shaped box) is not cali legal just fyi. the old greddy blue box was made for cars that had OBD1 or 2, and the e manage works with OBD1 (personal experience)
I have a blue box from my greddy kit FS. I used it on my 2000 Si and it worked every year for me to get my emissions passed. I even made it to where I wired in the pigtail into my main harness so I could just plug the blue box in every year.
This should work for you as long as you wire it up correctly.
