greddy blue box need your help ! ! !
my boy try to work with this for his d16 turbo project and whene he connect the blue box, the enginge getting much more fuel and the motor shut down..
what we should do???
is there any map for this ??
thanks
thanks
Re: (turbodohcsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbodohcsi »</TD></TR><TR><TD CLASS="quote">you got it hooked up to the map sensor wire right?</TD></TR></TABLE>
yeah.. i need an help how to tune it for the d16 setup. becuase now it not tune for that
thanks
Modified by royJDMEG5turbo at 11:57 AM 4/14/2006
thanks
Re: (jnasty1845)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jnasty1845 »</TD></TR><TR><TD CLASS="quote">You sure u have the Blue box or the e-manage.
Becuase you cant tune with the Blue Box, only with the emanage.</TD></TR></TABLE>
i meant to play with the switches on it.
is there any way to do that?
we just need an map or somthing to tune it for the d16 setup
thanks
roy
thanks
roy
Re: (royJDMEG5turbo)
there is 2 switches there on the blue box..
maybe we can play with this and try to tune it for the d16 setup..
if any one knows how to do that we can pay for that if its need..
i really need this help
thanks
thanks
Re: (mike93boost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike93boost »</TD></TR><TR><TD CLASS="quote">wtf</TD></TR></TABLE>
lamo ..
i just asked question what is the problem???
lamo ..
Very Emergency!!
i had the greddy kit on my old single cam and it worked fine. it sounds like you need to go through and check your wiring. do not mess with the switches on the side of it. make sure that the the map "in" and the ma "out" aren't mixed up.
STFU.... nobody has a problam....
our boy roy here has a problam to pronouncing himself in english. LOL...
this guy is trying to run a bluebox with stock injectors on his sohc ZC with a p28 ecu.
he gets crappy idle..... its like the car is dying.... (and roy.... you dont know it its rich.... i'm sure that this bluebox is fucked up or that somone opend it up and played with the potentiometer.
Re: (emotionisdead)
the wiring is fine maybe the switches dont set as well and the need a change.
is there any man or somthing to read that show how to do that for d16 setup,...??
thanks again
thanks again
Re: (RACEPAK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RACEPAK »</TD></TR><TR><TD CLASS="quote">STFU.... nobody has a problam....
he gets crappy idle..... its like the car is dying.... (and roy.... you dont know it its rich.... i'm sure that this bluebox is fucked up or that somone opend it up and played with the potentiometer.</TD></TR></TABLE>
lamfo
lamfo
Do you guys even have the support tool? You do need that if you are goign to do the tuning unless you are also running the E-01 boost controller.
Re: (BoostedTL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedTL »</TD></TR><TR><TD CLASS="quote">Do you guys even have the support tool? You do need that if you are goign to do the tuning unless you are also running the E-01 boost controller.</TD></TR></TABLE>
blue box and emanage are two totally different things.
Re: (mike93boost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike93boost »</TD></TR><TR><TD CLASS="quote">blue box and emanage are two totally different things.</TD></TR></TABLE>
we know that. we just need an picture to see the switches in the blue box. maybe our blue box not tune for the d16 setup and thats what cause the problems..
i need an picture or somthing please
Modified by royJDMEG5turbo at 1:45 PM 4/15/2006
Re: (RACEPAK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RACEPAK »</TD></TR><TR><TD CLASS="quote">u cant tune a bluebox!!</TD></TR></TABLE>
i meant to change the switches mode..mmm
expletive you moshik
