Greddy 19T 3inch downpipe
whats so good about a bigger down pipe, if there is any and whats the down side about it? if so where can i buy the flang? or can i reuse my greddy one?
turbos need to breathe, the more a turbo can breathe the more efficiently it can do its job. I stock exhaust chokes the turbo so you increase the size to allow more breathing room....
Downsides are that you probably need to get it custom welded, you may lose your ac, depending on your manifold...
Not sure about the greddy flanges but depending on how big your current dp is you may be able to reuse it... just it off and at a 3" flare section but room becomes an issue...
You get get a new flange for pretty much any bolt pattern at http://www.atpturbo.com
civic-8442-
05-07-2009 07:18 PM
