Greddy 18g kit on a 2nd Gen Integra??
I dont care about the piping, since I have to get it made anyways.
I just want to know if the manifold/turbo/DP will fit without any modifications?
thanks
Tyler
thanks
Tyler
Guest
Posts: n/a
Re: Greddy 18g kit on a 2nd Gen Integra?? (ATgrills.com)
I have a g2 teg and it was a PITA to fit with a turbo. First of all you'll need to move to a pusher style fan on the front of the radiator because the fan most likely won't clear a turbo. The front cross member has a flange on it that is going to probably make fitting a standard downpipe difficult, I trimmed the flange. You'll probably have to relocate the battery. You might need to grind the webbing on the block a little. Don't get crazy, someone on this board actually cut into the water jacket doing that. THe manifold should bolt right up though.
Re: Greddy 18g kit on a 2nd Gen Integra?? (filetofit)
well I am using an AEM as my main charge pipe so i know that will fit fine, then ill get the rest of my piping made...
so my consern is the RAD and the Down pipe.. you dont think it will fine up at all?
Tyler
Tyler
