greddy 18g externally gated. . . ?
Old 09-17-2007, 02:06 PM
gsr x civic's Avatar
Default greddy 18g externally gated. . . ?
i'm running an 18g right now and i just got the internal wastegate welded shut. i'm also running a blox b series turbo manifold with an ultragate38 external wastegate. here are my mods. .
hondata s200b all options
dsm 450s
aem fpr
blox t3 flanged turbo mani
turbosmart ultragate 38 ex. wg
skunk2 intake manifold
greddy 2.5 to 3 in downpipe
greddy evo 2 exhaust
greddy manual boost controller
greddy type rs BOV
precision 375 fmic
greddy 18g
1.75 hot 2.25 cold ic piping
@ what psi would i need to make 300 whp? that's my goal. i remember talking to greddy a while back and i remember marshall saying that the max amount of psi that the 18g is able to put out is around 26 or 32 psi. would i even be in this psi range if i wanted to make 300whp?
any info would be great. thanks a lot guys!!!
Old 09-17-2007, 04:53 PM
jdmhotness's Avatar
Default Re: greddy 18g externally gated. . . ? (gsr x civic)
No not even past 20 with a good tune
Old 09-17-2007, 06:36 PM
Default Re: greddy 18g externally gated. . . ? (jdmhotness)
and why is that?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmhotness &raquo;</TD></TR><TR><TD CLASS="quote">No not even past 20 with a good tune</TD></TR></TABLE>
Old 09-17-2007, 10:13 PM
bump for helppp
Old 09-18-2007, 02:11 AM
TypeSLO's Avatar
Default Re: (gsr x civic)
i've seen at least one b16 making just over 300whp with an 18g but i don't remember his setup. i know it was running hondata too. that was on a stock block. won't know until you try. are you trying to figure out what size wastegate spring to get or something?
Old 09-18-2007, 02:22 AM
Boostdc4's Avatar
Default Re: (TypeSLO)
time to start thinking about bigger injectors
Old 09-18-2007, 05:17 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TypeSLO &raquo;</TD></TR><TR><TD CLASS="quote">are you trying to figure out what size wastegate spring to get or something?</TD></TR></TABLE>
no i'm just running a boost controller.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostdc4 &raquo;</TD></TR><TR><TD CLASS="quote">time to start thinking about bigger injectors</TD></TR></TABLE>
roughly, what would be the duty cycle for the injectors at high boost? and what size would i need?
Old 09-18-2007, 11:26 AM
bump for help
CivicGSR225
02-03-2005 06:27 AM
jbell
10-09-2004 04:54 PM
Sprockets
07-20-2004 02:37 AM
igo4bmx
01-20-2004 05:29 PM
Seedc2
02-09-2003 07:01 PM
Quick Reply: greddy 18g externally gated. . . ?
