greddy 15g: how much psi to obtain 200whp
Re: greddy 15g: how much psi to obtain 200whp (mike93eh)
a guy i read about dyno tuned his and 15psi was 248 on a y8 motor so kinda go for there heres the thread link https://honda-tech.com/zerothread?id=1356768
im at 181 with 7lbs,but thats with a dohc zc. I would think with a kteller downpipe and a pound more, id be over 200
Re: (liam821)
its all about tuning and air flow bigger turbo's make more power with less boost example a 15G might make 200 whp on 10 pounds when a 20G might make 200whp on 7pounds all about air flow I have a friend tuning with only a fuel pressure regulator and ran a 12.6 he got 3 hours on the dyno went to the track and ran a 11.8 in conclusion its all about tuning and air flow just put the set up on and work with it till you put down 200
I don't think there is a solid answer to your question.....There is no single PSI that will obtain a set amount of horsepower. It is dependant on your engine, fuel management and the tuning. And every engine is different, 2 engines of the same engine stand build by the same person can have distinctly different characteristics. Just take it to the dyno and see where your motor makes 200hp.
pelotudo
08-12-2002 09:39 AM
