Great, I just found out the top hole on my Greddy Type S is stripped...???
I went to turn the bolt and it just poped out. The threads are completely stripped. Now what do I do? Do i need a whole new BOV? or can I get just a new top piece?
Re: Great, I just found out the top hole on my Greddy Type S is stripped...??? (ALL MOTOR LS)
can you just re-drill and tap the hole, get a larger bolt and your set.
Re: Great, I just found out the top hole on my Greddy Type S is stripped...??? (2.2Lcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2.2Lcivic »</TD></TR><TR><TD CLASS="quote">can you just re-drill and tap the hole, get a larger bolt and your set. </TD></TR></TABLE>
yea i had to do that with my brand new rfl because my vacuum line was hitting my hood and replaced it with a 90 degree
BTW: change your username.
I guess that would work. When I take off the top purple part, is there any kind of gasket, o-ring, or something that will need to be replaced when I put it back on?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ALL MOTOR LS »</TD></TR><TR><TD CLASS="quote">I went to turn the bolt and it just poped out. The threads are completely stripped. Now what do I do? Do i need a whole new BOV? or can I get just a new top piece? </TD></TR></TABLE>
VERY COMMON prob with the type-S
Re: Great, I just found out the top hole on my Greddy Type S is stripped...??? (FourceFed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FourceFed »</TD></TR><TR><TD CLASS="quote">
BTW: change your username.</TD></TR></TABLE>
me???? why ??
Modified by 2.2Lcivic at 4:00 PM 12/7/2003
me???? why ??
me???? why ??
Modified by 2.2Lcivic at 4:00 PM 12/7/2003</TD></TR></TABLE>
i think ht was talkin bout all motor LS
me???? why ??
Re: Great, I just found out the top hole on my Greddy Type S is stripped...??? (project dc2)
when that happened to my type s i didnt have anything to re thread it with so i just took the nut from the top of the BOV and jb welded it to the bottom. the nut acted as the thread and it never came loose or anything.
Re: Great, I just found out the top hole on my Greddy Type S is stripped...??? (gordox)
Hmm, I may have to try that if I can't find anybody to re tap it. Do you ever find that the screw has backed out at all since your not using the nut as a lock nut?
You might be able to even do a nut on the topside as well as underneath... Either that or some blue locktite with the way gordox suggested.
