Got my VAFC installed today-blue wire mod ?
I know some people may not be impressed, but it worked the first time I turned my car on. Very different from the way things have been going (ex: I started my MPFI swap December 28 and finished it March 13). Now I just have to figure out how to use it. My turbo will be on by April 18, I have almost everything done. I made the manifold and downpipe (even made my own flanges). The charge pipe will be done once the turbo gets bolted in, and I have the oil lines almost done. I have the fittings in the block, but capped, and I made the drain flanges myself out of aluminum.
I will be making a VAFC install guide for 4G Civics as soon as I get a chance.
I have a ? on how the blue wire mod works, though. I hooked the blue wire to the O2 sensor wire, but how do I check the voltage?
Thanks!
-Dustin
Thanks!
-Dustin
Re: Got my VAFC installed today-blue wire mod ? (Autocratic_1st_Gen)
I think you can only do the blue wire mod with the S-AFC. The V-AFC's sensor readings are different. I think the blue wire on the V-AFC goes to VTM or somehting like that.
racinskittle
07-30-2003 11:42 PM
