good thing to try that? diy 02-wb
Re: good thing to try that? diy 02-wb (legendboy)
Of course you could do that but why do you want to save money. lol
I'm trying this with an aem ems...I think it will work fine.
What is this crap?
Re: good thing to try that? diy 02-wb (TriK)
i built the oz-diy-efi
it works as advertised. its a good kit. as far as i can tell, its pretty accurate.
It reads 14.7:1 at part throttle with the stock ecu and stock o2 controlling fuel.
dustin also has this unit (he got a prebuilt unit when they offered them) and has reported it was never more than .1 or .2 off from the wideband at the dyno. definitely close enough.
BUT you NEED good electronics and soldering skills to build the kit, if you got that, that its an excellent project and worth the time.
between the main wideband circuit board and the 2 tiny boards in the display, plus assembly and building cables, it took me like 15 hours to do it all. it was a bit more work than expected but definitely worth it in the end.
plus, i'll be tuning my motorcycle carbs with it in the future.
Re: good thing to try that? diy 02-wb (falconGSR)
Would it be a good idea to run the civic wideband 02 sensor instead of my factory integra 02 sensor?????
The same sensor is used with the DIY and FJO wideband kits.
What is this crap?
Re: good thing to try that? diy 02-wb (Speed PHreak)
I was reading thru the process of the DIY wideband and it's definitely way over my head. Anyone willing to put one together for me?
What is this crap?
Re: good thing to try that? diy 02-wb (Prelude_RCR)
What is this crap?
I'm gonna build it!
edit - also i just noticed that they offer a ready made cable from the NTK sensor to the WIB o2 controller box, but its gonna be a bitch to get thru the firewall with the fat connectors on the ends already. might want to build that cable yourself.
What is this crap?
No room for A/C, but my chassis had is stock. I removed the condenser box and ran the sensor wiring through it's hole in the firewall. It provides just enough room to get that beeoch plug though.....Check that link I posted above for an album of the install.
What is this crap?
Re: good thing to try that? diy 02-wb (dustin)
I think you don't know what connector I'm referring to:
You can build a great electrical device like this, but can't drill a hole thru the firewall? LOL! j/k
Seriously, how much would a fully assembled piece cost? Or how much would someone charge for it? I can get the VX O2 sensor myself...the rest is all Greek to me!
I just ordered all the components from digicom for $53 cdn. I can also ordered the vx o2 sensor for $233.xx CDN
I'll do the lcd display & datalogging after I finish the unit to see how it goes
I built one for GSRgrrls car...I don't know what you are all complaining about? It was EASY!
(I do offer assembly services!... IM me)
