Golden Eagle Sandwich Adapter Oil Filter types
Hi,
Got a problem after tightening it in to the block, i screw on the oil filter and have a gap where the gasket on filter wont reach the GE adapter. This is a Fram Filter, could it be that the filter threads are not deep enough.
Please let me know what filters u guys are using. Please help!!!thanks.
Re: Golden Eagle Sandwich Adapter Oil Filter types (PearlWhiteAccord)
Same problem with fram filters on my gem adapter. OEM or purolator filters seems to work fine.
Re: (skratchnsnift)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skratchnsnift »</TD></TR><TR><TD CLASS="quote">i use a fram with no problems. </TD></TR></TABLE>
Ditto! I've used 2 types of Frams now too, the regular ones and the Tough Guard ones.
Re: (Si Shane)
bought ac delco and it almost fit, still a very lil gap, dammit...
decided to lock that sandwich adapter tighter to see if that works...
can u guys tell me the size of the bolt?? i forgot and i couldnt find it on my extension when i did it few wks ago...i tried 7/8 and it was still too small.
Prelude chassy's don't want to clear... you have to notch out a bit of the rear member.
It also helps to check out the oil filters available and get the shortest one. Then you need to purchase a filter wrench that is one of those ring-expansion types.
datamonkee
12
07-03-2008 01:43 PM
