Golden Eagle sandwich adapter leak
My GE sandwich adapter has had a slow leak since it was installed. I didn't install it myself, but I noticed during my previous oil change that the 1" nut wasn't tight enough. I tightened it down and assumed this had fixed this problem. Yesterday I did another oil change and noticed there was still oil seeping from it. Oil pressure has been perfect, but I like to keep things clean. Golden Eagle is going to send me a new o-ring. I want to make sure it's done perfectly after the o-ring replacement. They were pretty vague about how much to tighten it down and weren't able to give me a torque spec. Should I assume that the torque specification would be the same as what's on the oil filter?
Re: Golden Eagle sandwich adapter leak
Originally Posted by Sprockets
(Post 51678639)
Originally Posted by TheShodan
(Post 51678758)
What did Golden Eagle have to say about it?
By the way, is there a way to stop these annoying "what's new" popups I get lately? |
(Post 51678796)
They told me to "hand tighten" it, lol. That could mean anything.
(Post 51679107)
Hmmm. I haven't seen those at all. .. Any blockers you can activate on the device you're using? (Computer, phone, tablet, etc?)
Oh. The intro of the new features. It only happened to me once. But not sure how it happens every time.
Check with IB Jose |
Try clearing your cookies/cache for this website (or just the whole browser) and reload, see if you can clear it out and get it to stay off after that.
"Hand tight" is definitely a relative term, but I'd just get it on there nice and snug without choking the absolute living shit out of it. Twist it on until you feel a healthy amount of resistance, without putting all your muscle into it, and call it a day. |
Originally Posted by Chance EG
(Post 51679281)
"Hand tight" is definitely a relative term, but I'd just get it on there nice and snug without choking the absolute living shit out of it. Twist it on until you feel a healthy amount of resistance, without putting all your muscle into it, and call it a day. It was nice and snug, and I'm sure the other guy had it that way. They need to list torque specs. I don't see why they wouldn't. |
(Post 51679763)
Most places no longer utilize that type of information as something that they would use in a type of owners manual or diagram . |
(Post 51679952)
They may not have that.
Most places no longer utilize that type of information as something that they would use in a type of owners manual or diagram . hi shodan ive messaged you, was wondering if you got my messages ? Sorry to post this on the post. |
Originally Posted by phaphon
(Post 51680134)
if your sandwich adapter is not fitting right - you need to run a small spacer between the nut that screws to your stock oil filter threaded bolt in-between the adapter and the m12.x1.25 adapter for the sandwich I got a close fitting washer from a specialty nut shop (insert pun here) used an angle grinder to make it smaller overall circumference and it bolted up great.
This is with an ebay sandwich plate, the problem is that it bottoms out on the stock oil filter bolt so it cant get a tight fit. I think this is why so maybe people complain about sandwich plate leaks, because they dont install them right. This is pretty much the same sandwich plate that I am referencing: https://www.ebay.com/itm/Blk-Oil-Fil...IAAOSw~BhbFeOV |
(Post 51680134)
Shouldnt be any tighter then what you would tighten your oil filter. The Oring does the sealing not the torque.
(Post 51681269)
Sorry.. Haven't received anything from you
(Post 51682467)
just sent you a pm again |
