Golden Eagle Mfg. VTEC Conversion / Turbo Oil Feed!!!!!!! New Design Available!!!
Due to overwhelming demand, we re-designed our oil filter sandwich plate to fit on ALL engine models that accept the Honda style filter. No need to remove the nipple from the block, this new design allows you to simply remove your existing oil filter, screw in the Golden Eagle Mfg. oil filter sandwich adapter, and replace your filter. It's that easy and it work with existing oil cooler set-up like on the B16 engine. This will be available between April 15th and April 18th, 2003. Call one of our distributors to place your order and reserve yours today. Comes complete with full install instructions. Easy install, less than 5 minutes. Use this for clean filtered oil for Vtec oil supply to the head for LS/VTEC and CR/VTEC set-ups. Also can be used for clean filtered oil supply to your turbo and/or oil pressure sending unit. Also, there are multiple options for specific applications you may have. We will post some new pics and scenarios that this unit can perform. Golden Eagle Mfg; you talk, we listen, then we make it happen for you!!!
(909) 592 - 4311 for a distributor near you!!!!
Thanks.
Modified by GoldenEagleMfg.com at 10:57 PM 4/9/2003
Thanks.
I am a bad person
Re: Golden Eagle Mfg. VTEC Conversion / Turbo Oil Feed!!!!!!! New Design Available!!! (GoldenEagleMf
for making products that the customers want!!! Listening to what people want is #1!!!! GE = 100% high quality products!!!
pics will be up as soon as I get them back fro the anodizer!!! But it look almost identical to the old version!!!
that's awesome! Will pricing be the same as the old version?
finally its available i will be needing 2
what is your list of authorized distributors
I am a bad person
according to what he said in the 1st post
"It's that easy and it work with existing oil cooler set-up like on the B16 engine."
I am a bad person
I can get anything from GE. Pm for Info on purchasing what you need. thanks
do most people experience leaks if they try to tap the block at the pressure sender? im kinda trying to decide if i wanna pay the xtra 100 buck for this thing considering i already have my oil feed stuff ready to go...thanks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GoldenEagleMfg.com »</TD></TR><TR><TD CLASS="quote">This will be available between April 15th and April 18th, 2003. [/i]</TD></TR></TABLE>
SWEET! The 18th is my BDay! Do I get one for free?
This unit is just nice if you want a clean, sanitary no-hassle set-up. Tapping the back of the block was just such a pain and has such a good chance of leakage, breakage and so forth. This unit is very flexible to your application needs. We have numerous scenarios that you can use it on which I will post once I can get some pics done for you guys!
whats the difference between the old design and the new one...i actually just ordered one...the last of the old design i guess...what were the problems of the old design that you resigned it
do these have just 2 ports then, one for oil feed and one for oil pressure sender? I want to add an oil temp probe as well, can this adapter accomodate it or do I need to use a tee?
We will Offer these at $99 shipped to your door and we will have plenty in stock along with Vaccum Manifold for $45 shipped when they are released next week.
Modified by Howitt at 5:29 AM 4/10/2003
i have the "old" or past design that i just recieved today. i havent used it and its brand new...can i send it back in exchange for the new design because i do use a b16 cooler and i ordered this before any one had stated if it was useable w/ the b16s cooler or not vince?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Howitt »</TD></TR><TR><TD CLASS="quote">We will Offer these at $99 shipped to your door and we will have plenty in stock along with Vaccum Manifold for $45 shipped when they are released next week.
Modified by Howitt at 5:29 AM 4/10/2003</TD></TR></TABLE>
I'll be in for sure!!
