going turbo help?
im new to this forum btw
i have a DA and its mileage is 130,000 i have b18a1 everythings stock except for the intake and exhaust is the mileage bad for turbo? what should i do about that? i going to go turbo but idk wat i need to upgrade before putting it on like fuel pumps or pistons i wanna b at 7psi but have a boost controller too any help? |
Re: going turbo help?
well first 7 psi is gonna be different power levels depending on your turbo you use
130k on boosted motors... might not last a long time, maybe will depends on a lot of factors such as engine health, how much power your puttin through it, how much you beat it, and maybe tune what are your power goals and whats your budget? |
Originally Posted by azandford
(Post 42006091)
130k on boosted motors... might not last a long time, maybe will depends on a lot of factors such as engine health, how much power your puttin through it, how much you beat it, and maybe tune what are your power goals and whats your budget? and i want to get to about 220hp at least my budget is at 1100$ i can get the turbo kit pretty cheap (not some ebay one) ill prabably have about 300 afer i buy the turbo kit |
what about engine management? new injectors? tuning? thats a bit more than the 300 you have left
wats more important
so my motor will last? |
what do you mean whats more important? if you are gonna boost you need to get engine management, such as chrome which is free but you need to get your ecu chipped. then you need to get it tuned by a tuner. My tune cost me about 350, gettin the ecu chipped is about 60-75 bucks, plus whatever program you choose to tune with. Chrome is freeish but it can get really expensive if your looking for more options.
I would definently stick around and read all you can... dont rush into boost i boosted my stock engine and regret it now... i would have def. gone back and rebuilt it with good parts |
yea ima take my time
but how can i boost around 15psi safely? |
first you said 7 now you said 15 psi do you know that on dif. turbo sizes that 7 psi equals different power gains?
do you know anything about cars? have you done any research or do you expect to have everything handed to you? what you need to do is forget about boost, learn how to install a cold air intake, exhaust, headers, and so forth until you are comfortable with taking and putting things back together on your car i know you wanna go fast but believe me this is not something you want to rush into or cheap out on because in the end your gonna spend more money |
i do know about cars and i have done all my research
Originally Posted by mykulangot92
(Post 42008089)
i keep reiterating the fact that dif. size turbo equals dif. power on dif. psi get it? if you have done your research then you already must know the answer... theres nothing wrong wit being humble |
| All times are GMT -8. The time now is 10:58 PM. |
