b16 84mm what turbo for my?
build my b16 with:
darton 84mm
cp piston 10:1
eagle or manley rods
erl or eagle gridle
acl bearing
stock port head
stock valve
skunk2 pro spring valve
skunk2 pro1 cam
afi intake manifold b series
skunk2 74mm body
sls prototype t3 manifold
injector dynamics 1000cc
aem rail and regulator
DeatschWerks 300lph in-tank pump
aem ecu and coil on plug aem
exhaust full 3"
more or less this is the setup that I am in order to use, is in order to decide between upsets precision 6265 a/r 82 or 6765 a/r 82, than difference of spool approximately on mine setup?
I would want revving approximately 9500.
between 44mvr wastgate or 46mm precison wastgate? opinions?
darton 84mm
cp piston 10:1
erl or eagle gridle
acl bearing
stock port head
stock valve
skunk2 pro1 cam
skunk2 74mm body
exhaust full 3"
Re: b16 84mm what turbo for my?
approximately 600/650whp, but I do not want to be to the limit for future upgrade….
it would appeal to me late spool not more than 6000….
its a B16 rev that **** to 11k. id get away from the standard H beams if you are going to eventually go for more than 600. id go 6765 if you want room up top for future
creed to have determined to use 6262 a/r 82 ball bearing, with it I can still pull 9500 revving of power in climb on mine setup to approximately 30psi?
