H22 stock vs turbo cams rpm
What do you think about
h22 stock cams 7500rpm 14 psi 300whp
h22 pro1 cams 8500rpm 6 psi 300whp
Should be faster with higher rpm for less lag and spool time?
Re: H22 stock vs turbo cams rpm
Pro1 cams are most likely going to be oversized for that target power, with a turbo. What turbo & manifold are you using? That would matter a lot. Stock H?
Does Skunk have Tuner1 cams for the H22?
300 is a example, probably should be about 350
Is a t3t4
i think can be faster
If it were a diesel with variable geometry, the rpm would not matter so much
Is a t3t4
