Garrett PHX42 turbocharger results
Hello, I am new and searched for results on this turbocharger but have found little to no information on other forums. I see here that Peak Boost had tested on their evo w/ relatively low boost (around 30psi) with dismal results but since the thread is from back in 05-06... i cannot view the dyno graph to see how bad it lagged. Anyone w/ any concrete data on this turbo w/ a 2.0l 4 cyl? This is basically a gt4294r in what seems to be an s-cover. My particular one we have at the shop has a q-trim i think in T4 .81 exh housing.
-Tom
-Tom
Re: Garrett PHX42 turbocharger results
looks like you are going to have to test it out and let us know how it goes!
PS when do I get to see the beast run!
we were told it would spool quicker than a 4294r than in its original housing... but lose a tad of top end. This is in a T4 .81ar... So i was pegging it to act like a 67mm in a T3 .82? Just guessing as I am not the most knowledgeable w/ turbos. Im guessing from your response that perhaps the smaller housing may upset how it works?
-Tom
OG Fabricator
Stay far away unless you want an expensive paperweight.
It wasn't usable because it would break with in a few passes. Large compressor wheel, small turbine wheel, small shaft....say goodbye to the thrust bearing.
hmm, that i could understand. But the example we have is a large shaft and the turbine seems to be the appropriate wheel for a 4294r. I mean the entire chra looks to be from the 42r just the housings are smaller? Here's a pic of what fell into our laps...
Never heard of anyone using it, i think a lot of people got over the big wheel in a small chassis thing real quick.
yeah, we've been using Forced Performance billet turbos over here... just this thing landed at our feet and it seemed interesting to try out. I also, cannot find any useable results from anyone. Well, i will be testing it next week... so I'll post results on a new thread bad or good, lol.
riceball777
06-22-2013 05:54 AM
VTC_CiViC
03-21-2006 12:54 PM
Pfieff
07-29-2004 02:05 PM
