G35 Muffler on Turbo Accord
Old 06-29-2004, 12:33 PM
abeaujuin's Avatar
Default G35 Muffler on Turbo Accord
I have a turbo 94 accord Ex. I resently installed the Muffler from a G35 Infiniti and a high flow Cat. I dyno the car it did 196 Torque and 166 HP.
I know I can do better. I felt some restrictions after I installed the Cat and Muffler.
Would it come more from the G35 Muffler or the High Flow Cat?
I installed the G35 Muffler because I thought a V6 Muffler on a turbo 4cyclinder would work fine.
I want to remove the Cat, but I don't want to remove it and come to find out that the Muffler is really the issue.
I want to try the least expensive first ( remove the Cat) Can someone give me an opinon on this one?
Old 06-29-2004, 01:10 PM
ykracing's Avatar
Default Re: G35 Muffler on Turbo Accord (abeaujuin)
the cat was probably more of the issue, I would think.
also, arent the g35s dual exhaust?
because then you put a 3cylinder muffler on a 4cyl turbo.
Old 06-29-2004, 01:16 PM
abeaujuin's Avatar
Default Re: G35 Muffler on Turbo Accord (trboCIVICWRX)
Don't the 6 cylinder flow into one pipe? then into one muffler?
The G35 is one muffler 2.5 inlet with Two 2.5 Outlets.
So you think the muffler would be fine?
Old 06-29-2004, 01:33 PM
ykracing's Avatar
I guess that I dont know. I though that they were dual exhaust with two mufflers...
maybe Im wrong.
Old 06-29-2004, 03:25 PM
B20luda's Avatar
are u still on stock piping diameter?? that would cause it also...
Old 06-30-2004, 06:48 AM
abeaujuin's Avatar
Default Re: G35 Muffler on Turbo Accord (B20luda)
I am running 2.5 from the downpipe. I am going to remove the muffler tonight and drive the car to see if I get more power, before I go and get a test pipe installed. I can easily remove the muffer but the Cat test pipe needs to be done by a welder.
Old 06-30-2004, 06:55 AM
Mad Cow's Avatar
How does the muffler sound?
Old 06-30-2004, 07:02 AM
abeaujuin's Avatar
Default Re: G35 Muffler on Turbo Accord (Mad Cow)
Very close to the G35.
Old 07-04-2004, 08:29 AM
Moog's Avatar
How in the he!! did you install a G35 muffler? It is a rather large piece that would not readily fit underneath your 5th gen Accord. I'd have to call BS.
Old 07-06-2004, 06:25 AM
abeaujuin's Avatar
Default Re: G35 Muffler on Turbo Accord (Moog)
How do I post an image on this site?
Old 07-06-2004, 07:24 AM
Mad Cow's Avatar
Host it somewhere, then use the IMG tags.
Old 07-06-2004, 10:20 AM
Overblown-Teg's Avatar
That muffler is the problem. you want a straight through muffler. Any baffled style muffler is going to kill power
Old 07-06-2004, 11:26 AM
abeaujuin's Avatar
http://www.angelfire.com/ga/arnold/MVC-003X.JPG
http://www.angelfire.com/ga/arnold/P6250150.JPG
Old 07-06-2004, 12:33 PM
Circuit Star-29's Avatar
Links do not work.
Right click on the image, and go to properties. Highlight and copy the address next to the URL. The put that address in between the image signs. Like this-
IMG]"address here"[/IMG
Old 07-06-2004, 12:43 PM
shadow103rd's Avatar
pics work fine. I like the install. How is the piping ran because the G35's are dual exhaust.......
Pics of the exhaust under the car if possible
Jon
Old 07-06-2004, 12:54 PM
abeaujuin's Avatar
Default Re: G35 Muffler on Turbo Accord (shadow103rd)
I haven't taken any pictures of the underneath The G35 is a single inlet into a muffler with a dual outlet.
http://www.angelfire.com/ga/arnold/MVC-001X.JPG
http://www.angelfire.com/ga/arnold/PICT0106.JPG
http://www.angelfire.com/ga/arnold/PICT0117.JPG
These are the images of the G35
Old 07-06-2004, 02:59 PM
Pics dont work
Jon
Old 07-06-2004, 03:20 PM
integra-modder's Avatar
copy the link address by right clicking on the link and selecting "Copy Shortcut"
Then goto this page: http://www.angelfire.com/ga/arnold/
Now paste the link, and enjoy the picture.
Old 07-06-2004, 03:25 PM
Default Re: G35 Muffler on Turbo Accord (integra-modder)
Wow abeaujuin,
When I read the thread topic I was laughing and was thinking you were on crack. Now that I see what you did and how it looks I am very amazed.
Awesome job. I wouldnt take off the muffle just because it looks like it belongs there. Take off the cat if your area (emissions testing) permits.
Have you considered a high flow cat like a Carsound Cat? 55 bucks shipped on ebay: http://cgi.ebay.com/ebaymotors...33629
Old 07-07-2004, 12:45 PM
abeaujuin's Avatar
I removed the Cat and this car rocks hard now.
I did have a High Flow Cat from FlowMasters installed, but I guess it didn't flow enough.
Old 07-07-2004, 12:47 PM
abeaujuin's Avatar
Now that I have the setup for a G35 Exhaust, I will get a Greddy for the G35 and bolt it right in. Which should flow better the the stock.
Old 07-07-2004, 03:53 PM
Moog's Avatar
Wow didn't know you would actually butcher your trunk like that....i stand corrected. Looks like a lot of work just to fit that muffler on there.
Anyways, here's better pics of the muffler ... stock is on bottom of pic.
Old 07-07-2004, 03:54 PM
Moog's Avatar
quick shot of my G
Old 07-08-2004, 06:23 AM
Jdm93civic's Avatar
when you say G u mean G as in Girl or G35...cause deng both banging
Old 07-08-2004, 07:10 AM
abeaujuin's Avatar
What exhaust is that you have on the other side? That one may work better with my turbo setup. Is it loud? Does it sound closer to your stock muffler?
Quick Reply: G35 Muffler on Turbo Accord
