Full boost all gears
All motor 600whp 8.5s 60ft 1.4s
why boost by gear? Why not full boost all gears 600whp? |
Re: Full boost all gears
You cannot do "boost by gear" on a NA engine... but normally, you reduce boost in lower gears so that you can control wheel spin and then dial up the boost in upper gears when your vehicle speed is high enough to reduce or eliminate wheel spin.
Originally Posted by JRCivic1
(Post 53013727)
why dont use 600whp all gears in turbo? |
Because fwd has its limitations. Bbg is the best way to have allot of power and still make it somewhat useable on the street. There’s a big difference from a prepped track and wrinkle wall slicks to street tires on the road.
...link to 600hp n/a build
| All times are GMT -8. The time now is 07:48 PM. |
