Fuel system
Im planning out a motor and was just curious if my fuel system is adequate. max 450whp on race gas. T3/To4e. B16 with 84MM goldenb eagle sleeves. I was going to use a 255 in tank pump, regulator and 660CC injectors. sound good? Hondata tuned. Thanks guys
Tom. |
Re: Fuel system (simple4012)
Nope! If you serious about running 450whp then you should consider getting a big aeromotive external fuel pump with Steal braided lines as fuel lines. -8 to the rail and -6 to return. As well as get bigger injectors. I would use at least 720cc injectors.
HTH |
| All times are GMT -8. The time now is 09:25 AM. |
