Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Forced Induction (https://honda-tech.com/forums/forced-induction-16/)
-   -   fuel setup for 450whp on e85 (https://honda-tech.com/forums/forced-induction-16/fuel-setup-450whp-e85-2845589/)
golf-mk3 Oct 6, 2010 06:59 AM
my goal is 450+ whp. 60-1 turbo. so far i have 1000cc injectors and bosch 044 pump. can i use my stock fuel lines, fuel rail, and regulator to make that kind of power on e85?
93turbo16 Oct 6, 2010 07:16 AM
Re: fuel setup for 450whp on e85
What 1000cc injectors do you have?
If you have the ID 1000cc injectors then you should be ok, as long as you run a higher base pressure with an intank walbro and the bosch 044.
So the stock regulator might be your limiting factor as you will definitely have to turn the fuel pressure up.
golf-mk3 Oct 6, 2010 09:09 AM
prescision injectors. and your recomending running 2 pumps. in take 255 and in line bosch? any recomendations on whats a good FPR with stock rail?
golf-mk3 Oct 7, 2010 05:27 AM
anymore input
