fuel injection help
i put 460 fuel injectors on my 92 hatch w/ bone stock ls and the car stalls as soon
it hits 5000 rpm what can it be... |
Re: fuel injection help (eglslsd)
is it tuned? is it even boosted? you said bone stock ls.
Re: fuel injection help (doood)
not tunned not boosted
then why do you have such big injectors in a stock untuned engine?
i put them on before i installed the turbo thinking it was not going to make
a diffrence im installing my turbo next week. i have a resistor box for the injectors but i didnt install it. if i install the resistor box wil it it make a diffrence. |
https://honda-tech.com/forums/images...s/emhammer.gif
put your stock injectors back in. your engine isnt running right because you have huge injectors, without resistor boxes installed, on a stock engine. even if they were running right you'd be running rich. wait until you're tuned before installing them. |
i am going to install my stock fuel injectors back in.
even if i put my turbo i wont be able to use my fuel injectors untill i get it tuned? |
bigger than stock injectors without a tune will make you run rich
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doood »</TD></TR><TR><TD CLASS="quote">bigger than stock injectors without a tune will make you run rich</TD></TR></TABLE>
yeah and running p&h injectors w/o a resistorbox will smoke the injector driver in the ecu. |
Re: fuel injection help (boostedcivicsir)
thanx for the advice
