found out i have a smaller a/r turbine housing than i thought!
i was sand-blasting my turbine housing today to re-paint it and after i cleaned out the inside ,i found that it has been a .48 housing all along.you could never see it before because of the carbon build-up.i just assumed it was a .63.keep in mind that the last dyno pull i made was 440whp with a slipping clutch.i estimate it to be 550whp now.i will be changing it to either a .63 or a .82.probably .82 if turbo specialties has one in stock.
Re: found out i have a smaller a/r turbine housing than i thought! (TurboD16Z6)
i'm running a .48 a/r turbine housing with a 1.6L.. going to be just right for 400-600 hp (w/nitrous)
it isn't a honda engine, though.
Re: found out i have a smaller a/r turbine housing than i thought! (lazerus)
i have a used drag 3 kit on for awhile and its a t3/t4 turbo, i cant tell what a/r it is though. any suggestions? i tried calling and they dont know either
I am a bad person
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lazerus »</TD></TR><TR><TD CLASS="quote">i'm running a .48 a/r turbine housing with a 1.6L.. going to be just right for 400-600 hp (w/nitrous)
thats pretty broad 400-600whp. what will determine if you make 400 or 600??
Re: found out i have a smaller a/r turbine housing than i thought! (turbotypeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbotypeR »</TD></TR><TR><TD CLASS="quote">i was sand-blasting my turbine housing today to re-paint it and after i cleaned out the inside ,i found that it has been a .48 housing all along.you could never see it before because of the carbon build-up.i just assumed it was a .63.keep in mind that the last dyno pull i made was 440whp with a slipping clutch.i estimate it to be 550whp now.i will be changing it to either a .63 or a .82.probably .82 if turbo specialties has one in stock. </TD></TR></TABLE>
what kind of turbo is it?
Re: found out i have a smaller a/r turbine housing than i thought! (Jordo)
Danny is running a t3/60-1 in a to4e housing. A 60-1 hifi if that's what you want to call it. Paul
If that exhaust housing will fit a T-3 out of a volvo, I'll buy it off you. My junkyard turbo is a .63 exhaust with a .42 on the intakeside. Which will be going on a d16.
Re: found out i have a smaller a/r turbine housing than i thought! (gtcali)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gtcali »</TD></TR><TR><TD CLASS="quote">If that exhaust housing will fit a T-3 out of a volvo, I'll buy it off you. My junkyard turbo is a .63 exhaust with a .42 on the intakeside. Which will be going on a d16.</TD></TR></TABLE>
i have already traded it in
damn thats sick . . sweet.
yo can you post your set up again . im building my motor now and wanted to see how you got your numbers.
thanks man
thanks man
theEGkid
09-22-2005 10:44 AM
JalopySiR
02-07-2003 06:48 PM
