Forgot to mark the impeller, how do I reassemble?
*sigh* How was I to know you should read the instructions before taking something apart. Just doesn't sound manly...
We ripper a T25 apart and didn't bother marking the impeller position. I've read repeatedly that failing to line the impellers back up can screw up the shaft balance. What should I do here?
Re: Forgot to mark the impeller, how do I reassemble? (Deo)
Looks like only two options.Run it for as long as it lasts,you might get lucky and it's close to being balanced.Or send it out to be balanced.
