fittings to mate up ss line to hardline?
does anyone make fittings that will bolt up hardlines to stainless steel braided lines? I'm trying to setup my fuel setup, but don't wanna spend too much money on all ss braided stuff
[Modified by paul_vang, 9:20 PM 11/6/2002]
Re: fittings to mate up ss line to hardline? (paul_vang)
well, i tried it before and you can, but the thing is you need a tube and nut fitting and you may need to cut the hardline to insert the tube and re-flare it again...
or, this is where I got stuck... you need a female fitting that is the same thread as the oil pan drain bolt, but DEEPER..it basically the same thread as the inlet of the fuel filter, if you can find that to any AN fitting, it can be done...so it goes like this AN fitting - Female ( for talk sake let's make it 12x1.5mm) Deep
I am gonna play around with it some more as soon as I get back to dallas
BlueShadow
10-29-2005 03:25 AM
