Filter on turbo?
I've done some searching and went to K&N's website.. Is there a specific small compact filter you guys are using or can recommend?
4'' inch inlet and needs to be low profile *UPDATE* If you are in need of a slim 4 inch filter for your turbo use this part number: K&N Filter Part number - RU 2510 will work with power steering as well. |
Re: Filter on turbo?
Originally Posted by Jimmy
(Post 50545072)
4'' inch inlet and needs to be low profile It's cheap & will flow like crazy. 9" X 2" $60 shipped: Spectre 47728, Spectre Xtra Flow Air Cleaner Assemblies | Spectre Here's the full list of sizes: Spectre Xtra Flow Air Cleaner Assemblies | Spectre Rob43 |
Originally Posted by Rob43
(Post 50545209)
Could you make something like this work for you ?
i have a a short height spectre filter from autozone. it has removable sections that varies from 4, 3.5, 3"s. ive used it on two different compressor housing in the last three years
My vote is the short-height Spectre filter from AutoZone as well. I have a couple that I've used on multiple ram-horn and top mount set-ups.
My bud lost a Garrett Turbo when that silver button let go and the turbo attempted to ingest it.
I have no idea of the conditions the filter was subjected to, or it's condition at the time of failure, but I've been running K&N since and avoided anything with small metal pieces inside. http://www.spectreperformance.com/im...-8168_Base.jpg Didn't know they made the kind with all rubber end caps like the K&N, I wouldn't mind that style. |
What sort of clearance do you have for a filter?
Are you going to run it off of the compressor housing directly or are you building an intake pipe to get the filter away from hot air off of the radiator? |
Originally Posted by wantboost
(Post 50547091)
I just do some mesh and a pipe clamp I made 600hp makes no problems.
Some driving areas require more filtration than a simple mesh screen.
I live in the country and sometimes go down dirt roads, I HAVE to have a good filter. |
Originally Posted by civiccivic123
(Post 50548695)
If you can't fit this you can't run anything but a mesh
K&N RU-2510 Universal Rubber Filter, Universal Air Filters or K&N RU-2520 Universal Rubber Filter, Universal Air Filters If you using top mount its no chance. http://www.ebay.com/itm/K-N-Universal-4-Air-Intake-Cone-Filter-102mm-RU-2510-Car-Truck-SUV-NEW-/281437288366?hash=item4186f837ae&vxp=mtr |
(Post 50548695)
If you feel that will keep your turbo safe, I'll simply say this......It's never a problem..Until it's a problem. |
he has room for an intake or straight filter after looking at his build thread
I always cringe when I see people using screens and hose clamps :(
I remember a thread where mesh was proven to cost power anyway...Surface area added up be a blockage :hammer:
I guess mesh can vary, but still... |
Most mesh occupies more airspace for a given size, meaning there's less area for air to pass through which means a restriction. There was a sight that showed you various mesh sizes and the percentage of airspace each had.
A quality filter will always outflow any mesh. The biggest problem I see with filters that have to be oiled is most people always over-oil them. This causes huge restrictions as the pores in the filtration media become blocked by the oil. I've even seen some over oiled so bad that the person found filter oil puddled in their intercooler. The new synthetic dry flow filters are the way to go. |
(Post 50549986)
A quality filter will always outflow any mesh. The biggest problem I see with filters that have to be oiled is most people always over-oil them. This causes huge restrictions as the pores in the filtration media become blocked by the oil. I've even seen some over oiled so bad that the person found filter oil puddled in their intercooler. The new synthetic dry flow filters are the way to go. A good standard K&N Oiled filter is fine. The over-oiling problem only occurs when people get over-zealous during cleaning. |
I've heard about the AEM filters before. There's another company that makes dry filters and they haven't suffered a failure on a turbocharger yet but I can't remember the name of they company.
Originally Posted by rudebwoy
(Post 50548841)
K&N RU-2510 Universal Rubber Filter, Universal Air Filters or K&N RU-2520 Universal Rubber Filter, Universal Air Filters If you using top mount its no chance. K N Universal 4'' Air Intake Cone Filter 102mm RU 2510 Car Truck SUV New | eBay |
That seems like it'd do a great job of sucking water straight up off the pavement.
Originally Posted by NotARaCist
(Post 50550774)
In addition, most honda turbocharged don't sit so low that it affects it anyway. Any Honda turbo that has a compressor facing the driver (US) fender typically is smart enough to make a 90* or 45* to face downward since there is no other room. Its all in the configuration. I have one of these myself. http://ecx.images-amazon.com/images/...AL._SY355_.jpg It fits over the filter like this: http://i5.walmartimages.com/dfw/dce0...c8aa82e.v1.jpg Not even a full $21 |
(Post 50550345)
That might be it. I know that there are synthetic media dry flow filters and stainless media dry flow filters. Again I can't remember the companies off the top of my head (Traumatic Brain Injury has caused severe long term and short term memory loss FML lol)
Also LightningTeg doesn't drive his car in inclement weather so no concerns over ingesting water. Plus his car sits at a fairly reasonable ride height so short of driving into a lake he wouldn't really have an issue. |
