Feedback Requested: Em1Dustin's B18c1 "Fun Daily" Topmount Build Thread
Ok guys I have a built b18c1 with : CSS CNC WERX je pistons eagle h beam rods Golden eagle oil squirter plugs crank has been turned and polished head is a stock b16 with type r intake fid1200cc injectors brms top mount tial 44mm vband wg aem e85 fuel pump Unknown catch can setup Garrett GT3076R turbo. I know I’m missing more.... can someone tell me should I upgrade the cylinder head or will the b16 work in stock form? I’m not trying to build a race car, just a "fun daily" |
re: Feedback Requested: Em1Dustin's B18c1 "Fun Daily" Topmount Build Thread
The head should be fine as is. The only thing I’d look into is running a set of gsr cams, as they will perform better than the stock b16 cams. Springs and retainers are never a bad idea, gives you the ability to rev it out a little farther on shorter geared b series trannies. Also gives some peace of mind since I am guessing with the power you will make with that setup, you’ll be hitting the rev limiter quite often ;) |
Re: B18c1
Thank you for the advice. I was wondering about that. I also heard that gsr cams are good to run. This is somewhat of a "budget build" and I don't have loads of cash but it’s still costing me money. |
Since you have such a nice block, I'd at least invest in some Supertech/Ferrea springs and retainers for longevity and peace of mind.
GSR, ITR/CTR, or S2 Tuner 1 cams would be a nice little upgrade over the stock B16 cams, but not by any means required. GSC T1 cams along with their associated valvetrain would rock on your setup, but I'd advise you to read on some of the recent threads about the GSC cams along with spring type vs. oem hydraulic LMA's before going that route. |
Where exactly can I find that thread if you don’t mind copy post it please |
Be ready to read a bit, it's a long thread (great info though) -
https://honda-tech.com/forums/forced...ng%2A-3321519/ Depending on your funds you may be best off just keeping your B16 cams and upgrading the springs/retainers. Your setup would respond well to any of the cams that I listed, but by no means are they required. |
GSR or Type R cams with some springs and retainers is only thing I would change.
Re: Feedback Requested: Em1Dustin's B18c1 "Fun Daily" Topmount Build Thread
A stock port b16 head will be just fine, however I would buy a kit just like the one in the below link.
A full Ferrea valve train for $885 the only thing missing from the kit that I would also get is Ferrea locks which is only $70 bucks and might as well get new valve seals which again is very cheap. For less than a $1000 dollars you would have an absolutely solid valve train and peace of mind that the stock parts are not going to fail. https://www.ebay.com/i/221386303747?...3D221386303747 |
OP, do you already have the top mount manifold?
AZ_Civic has a good idea, but with that kit you'd also want bronze valve guides to accommodate the valves. If you wanted to keep things on the cheaper side and still reap some benefits from a stronger valvetrain, just do springs, locks, viton valve seats, and retainers. |
Originally Posted by AZ_CIVIC
(Post 51691520)
Originally Posted by Balor_Gr
(Post 51692325)
(small quick out of subject Author might be interested too) Have you ever used the 80lbs ferrea above 30 psi? Thats the kit a have and ferrea told me with kelford 176-T no more than 30 psi :(
Thanks. Thats very precious data.
