Faint "Squeak" when car is turned off
Old 09-17-2002, 10:36 AM
Rory Breaker's Avatar
Default Faint "Squeak" when car is turned off
Every time I turn the car off, I get a faint "squeak." It definitely sounds like its a rush of air when the car is turned off, and for some reason it squeaks.
I've checked a ton of vacuum lines for leaks, tightened the bolts on the manifold (JRSC) and still it persists. If I remove a vacuum line from my bypass valve to the TB, then the rush of air exits from the TB nipple without the squeak.
Any ideas on what exactly the noise is, and how can I make it stop without unhooking lines and causing a leak?
Old 09-17-2002, 12:10 PM
Default Re: Faint "Squeak" when car is turned off (newgsrdriver)
Any ideas?
Old 09-17-2002, 12:34 PM
New User
dbman96's Avatar
You're just hearing atmospheric pressure air "leak" back into the manifold and any vacuum reservoirs, all of which was under 20" vacuum right when you turned the car off. I get this on my car too.
Old 09-17-2002, 01:22 PM
Default Re: Faint "Squeak" when car is turned off (dbman96)
I've never heard this before though...why does it all of a sudden occur?
suprastitions
08-16-2016 09:55 AM
Hi Hater.
12-31-2008 08:53 AM
Quickgti1.8t
04-01-2006 06:18 PM
DaX
06-04-2004 09:19 AM
93H22ACX
02-09-2003 03:37 PM
Quick Reply: Faint "Squeak" when car is turned off
