Extra Things I had to buy When doing my Turbo Kit
I don't know if this will help anyone but i figured i would put it up just in case. Money might be tight for you so Hopefully this will help people plan better and not make as many parts runs as I did. I didn't post the obvious stuff like couplings, oil return and feed, etc... Hopefully you have already thought of that kind of stuff. I know it isn't alot of money but rather just a pain to run around if you are doing it by yourself.
Zip ties assorted Sizes $6 AutoZone
Tees for Vaccum $5 AutoZone
Vacumm Line 4 ft $5 AutoZone
Exhaust Flange Gasket $1 AutoZone
O2 Sensor Weld Fitting for DP $9 Jegs
2 Hexbolts and Washers to bolt down Wastegate $2 HomeDepot
1 3/4 inch Drill Bit thing to drill hole in ChargePipe for BOV $6 HomeDepot
14 Clamps for Couplings $16 Home Depot
Mobil1 Oil $23 (6 pack)
4 Grade 8 DP bolts $3 Roush Hardware
Oil Filter $4
Roll of Ducktape to tape together piping before getting welded... $2 Autozone
Hacksaw Blade to cut DIY Piping and SS Lines $3 Home Depot
Kerosene to keep the Garage Warm $9
Flange to connect DP to Cat or Test Pipe... $5 Muffler Store
4 Grade 8 Bolts to connect turbo to Manifold $2 AutoZone
Something to cut your bumper and other plastic on your car(in my case a dermel tool) $10 Homedepot
Exhaust Gasket $20 Acura
Hondabond for Oil Pan Gasket $5
I know it would of helped to get diminsions of bolts and whatnot but i forgot them. I guess these are the things that made me run around a bit more than I shouda. Hope this helps at least one other person out.
Corey
Oil Filter $4
Corey
ZCHF2
03-12-2003 12:52 PM
