External wastegate horsepower gains
Old 10-26-2011, 12:50 PM
Fnix's Avatar
Default External wastegate horsepower gains
Low boost small turbo setup, is there any horsepower gains worth the extra bucks for it?
12 PSI t3 60 trim
Old 10-26-2011, 01:29 PM
viper_boy403's Avatar
Default Re: External wastegate horsepower gains
YES! I gained 23hp (from 219 to 242) on 9psi with a tiny turbo by removing my cat and adding an external wastegate. Much better overall powerband as well
dyno charts
internal wastagate:
external wastegate and no cat (dotted line. solid line is with an open exhaust cutout):
Old 10-26-2011, 01:32 PM
oldskoolscraper's Avatar
12 PSI t3 60 trim
All in all I wouldn't say major numbers. The main thing you "gain" is something you "lose" which is boost creep. A lot of the internal setups take a little longer to spool sometimes because the wastegate will let a some go buy at first. Running an external wastegate and a booste controller is something I alwas recommend. Opinions vary, just what I've learned over time. Good luck
Old 10-26-2011, 01:34 PM
Fnix's Avatar
dyno charts
internal wastagate:
Did you have a closed dumptube or open?
Old 10-26-2011, 01:40 PM
initial setup was an internal wastegate. currently running open dump
Old 10-26-2011, 01:44 PM
909Drag's Avatar
x2 what Viper_boy403 said, with another car I had its setup was internal and I would spike 28 but could only hold 23lbs. When I switched to external wastegate with an open dump I spiked 30lbs and held 30lbs (of course with a stronger spring upgrade)
bsmith100
11-30-2008 08:27 PM
gsr x civic
04-07-2007 09:57 AM
16vt
05-29-2005 10:55 AM
nolovenodie
11-08-2002 02:43 PM
Quick Reply: External wastegate horsepower gains
