external wastegate failure symptoms
Re: external wastegate failure symptoms
won't build past 2-3 psi if that hi. falls flat at that point. can rev all you want sitting still but when driving you ain't got nothin when it should be building boost.
delta. was fine til I had to rebuild the bottom end cause of a cracked cylinder. then when reinstalled had this problem. when taken off turbo and wastegate were removed all one unit. don't know if when block screwed up it blew something in it or what. turbine spins nice. i'm at a loss.
