Everytime I boost, my coolant overflow bottle fills.
Re: Everytime I boost, my coolant overflow bottle fills. (Paul_Vang)
I have reused my stock gsr headbolts when I put my 3mm headgasket in. Could it that they are just loose?
Re: Everytime I boost, my coolant overflow bottle fills. (hydroflip)
get new arp headbolts...never reuse...and adj to torque specs....
Anyone know where to get them?
[Modified by Andrew 825SM, 1:23 AM 2/23/2003]
Re: Everytime I boost, my coolant overflow bottle fills. (Andrew 825SM)
When my car is cool, the coolant level is low, and after the car warms up, like after a drive, the coolant level goes up a little. I dont know why, but it does, and I know 100% I dont have a blown headgasket. If it over flows alot, it could also be that your car is overheating. Maybe not drasticly, but a little bit. Good luck!!!
Re: Everytime I boost, my coolant overflow bottle fills. (MiraiZ)
can you bleed the air out of the coolant system, are both hoses getting hot. Maybe an air bubble. thats what I had.
Re: Everytime I boost, my coolant overflow bottle fills. (333)
maybe your thermostats not working and opening all the way as well. Try a new one maybe?
What is this crap?
Re: Everytime I boost, my coolant overflow bottle fills. (TurboSiCoupe)
Re: Everytime I boost, my coolant overflow bottle fills. (falconGSR)
Yea I was wondering, my overfill bottle doesnt fill up...but some coolant does go into it only when I do a hard run. I also have white smoke on start ups, but after my engine is at normal temp, the smoke is gone. I'm having trouble diagnosing my problem to decide if I really need to replace my head gasket or if something else is the culprit.
A little coolant going back into the overfill bottle is normal due to expansion.
white smoke on startup = coolant being burned. Could be your headgasket.
Check compression on your cylinders.
Re: Everytime I boost, my coolant overflow bottle fills. (machaf)
Couldn't he also have some valve guides going out to cuase this? It would be a blue/white smoke then not a pungent white though
[Modified by Xscream, 9:23 AM 2/24/2003]
It's 100% normal for a little coolant to over flow to the coolant bottle when the engine is hot. When the engine is cool, the coolant should recovered back into the radiator. When you start an cold engine, it's also 100% normal to see some white exhaust smoke (not heavy) until it's warmed up. If the radiator is not losing any coolant, coolant smell in the exhaust, over heating, or oil turns to milky color, you should be fine.
But check everything else first to see if you can remedy the problem. Afterwards, if it's still happening, then I'm sorry but you'll have to replace the bolts. (Might as well do it anyways)
do you have an aftermarket radiator? or oem? oem tends to blow chunks. they use ceramic with an aluminum core. i had a problem similar to that, but not boosted, and i let it go and finally it blew and splattered all over my window while i was driving. check the top of your radiator and see if coolant is seeping out of the top....but that's only if you have a stock radiator.
totsie7944
06-20-2008 10:15 AM
tremor86
07-04-2004 04:22 AM
tremor86
07-03-2004 03:14 PM
