ESP.net's 2.3L Turbo Crx :)
Here is the Recap: www.ExplicitSpeedPerformance.net
This was going to be my 2nd time toying with turbo and going to the darkside... I was going to boost the stock H23A Vtec Blue Top block however decided to rebuild it so it could handle more then the standard 8-12 psi. Goal now is to be close to the edge for a street car. Looking for roughly 400+ whp and some crazy torque with the 95mm at around 14-16 psi on pump.
Current NA status:
- JDM H23A Vtec Blue Top Stock Internals!
- JDM H22A M2B4 LSD trans
- 9lb chromoly 1 piece flywheel
- ACT HD clutch kit 6 pad sprung race disc
- Converted OBD1 http://www.Rywire.com p28 crome tuned
- Euro R intake manifold http://www.RoskoRacing.com
- 68mm Performance Products TB
- ESP EF H22A Motor Mount Kit
- ESP EF H22A Traction Bar System
- ESP 4-2-1 H22A Header 2.5" collector
- 3" Cold Air Intake, BPI stack, K&N filter
- 3" Quick Dump Magnaflow Exhaust
- 212 whp 174 trq trap speed is 106 mph 22" MT's
Recent picture with the H23A Vtec Blue Top in...
NA tune:
Here's it is Now: Went Big instead of justing boosting stock block and Rebuilt it.
Here is the Build Details:
Engine/Trans:
- 2000 JDM H23A Vtec Blue Top
- Darton MID Sleeves STD bore
- JE 9-1 pistons/rings STD bore H22
- H23 Crower Rods
- Stock H23A Vtec Blue Top Crank
- ACL Std bearings
- Kaizen Speed Balance Shaft Eliminator Kit
- PDE Euro R/ Type S design HEAD (rare but some H23 Vtecs came with this Head)
- 60k thick MLS Cometic HG bumps final Compression is about 9.6-1
- Ferrea 6k SS valves, guides, seals
- SuperTech Valve springs and retainers
- Type S cams
- LiL PnP on Exhaust runners
- All new OEM seals and pumps etc.
- Balance Assembly, Action Machine did the sleeves, bore n hone, Balancing
- Engine B20Luda Built!!! Thanks Mitch
- M2B4 JDM LSD H22 Transmission
- LSD Motorsports 9 lb 1 piece Chromoly Flywheel
- ACT 6 pad sprung race Extreme series clutch kit 494 ft lb torque
- Euro R/F20B/H23A Vtec Alt. Only crank pulley
- NEW ESP Product Upper D OEM alterantor kit
- NEW ESP Product EF H/F Traction Bar System with Front Torque Mount Kit
Turbo Kit:
- Custom Turbo Mani
- Tial Q Bov
- Tial MVS 38mm WG
- T3/To4e Custom Big Wheel 50 .63ar
- 880cc Precision Injectors
- Walbro 255 HP Fuel Pump
- Marshall FP gauge and B&M FPR
- 28x6.5.2.75 IC
- 2.5" Hot and Cold IC Aluminum Piping RCautoworks.com
- PWR custom EF radiator
- Jaz Catch Can
- 3" downpipe and 3" quick dump magnaflow exhaust
Electronics:
- P28 Ectune and Ectune EBC (boost by gear)
- AEM Wideband
- Autometer Oil press. and Boost
Trailering Car up to James @ SpeedFactoryRacing.net to be tuned on Wed. Will post results. Hopefully get to drive it home for the first time on boost
Current NA status:
NA tune:
Engine/Trans:
- H23 Crower Rods
- ACL Std bearings
- Type S cams
Turbo Kit:
- Custom Turbo Mani
- Tial Q Bov
- Tial MVS 38mm WG
- 28x6.5.2.75 IC
- Jaz Catch Can
Electronics:
- AEM Wideband
Re: ESP.net's 2.3L Turbo Crx :)
Update:
Took me a bit after figuring ectune out and getting all the straighten out...
Dyno is Tom.!!! My Intercooler is going to limit me right now but wasn't shooting for crazy power yet. I am hoping for around the 400 whp mark 14-16 psi. I think I am being lil conservative...
Update:
Synapse made the mani
Haha motor held fine thanks Mitch!
I will post the dyno sheet tomorrow...
She made peak power of 411 hp and 340 trq at 15 psi... 4k rpm 275 ft lb torque. at SpeedFactory in Tacoma, WA www.SpeedFactoryRacing.net James is a great tuner! thanks again!
Never turbo'd before took her down the street for lil drive... half throttle brought a smile to my face hankookies are just not going to cut it! haha
Next plan is to get her broken in change the fan to a better flowing one... and put the slicks on a take her down the track.
